arcPy findAndReplaceWorkspacePath Won't Update Rasters
2231
03-14-2017 10:54 AM
LloydBronn
I'm using ArcGIS 10.3. I have an MXD that contains symbolized global raster images. I have a GP tool that masks these rasters to a country or state and exports the images. I'm trying to update the source background layers and rasters each time a new country is chosen. The layer names are all generic, but the source files all have the country or state name tagged on.  findAndReplaceWorkspacePath works just fine with the background layers (shapefiles), but it won't update the rasters. I've confirmed the old and new sources with print statements, it's just not changing the source. The only time I get images is if I use the default state (Texas) set in the MXD. If I choose any other location, I just get a blank country or state outline image.
Here is my code snippet:
layer_list = ["Precip","High_Temp","Temp_Departure"]
for filename in layer_list:
layer_name = filename
for lyr in arcpy.mapping.ListLayers(mxd):
 if lyr.supports("DATASOURCE"):
 if layer_name == str(lyr.name):
 old_source = os.path.dirname(lyr.dataSource)
 ##print old_source + "\\" + layer_name
 new_source = country_temp_path
 ##print new_source + "\\" + layer_name
 lyr.findAndReplaceWorkspacePath(old_source, new_source, False)
return()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
LloydBronn
Just got it to work
                    if  lyr.isRasterLayer:
                        lyr.replaceDataSource(new_source, "RASTER_WORKSPACE", input_country + "_" + layer_name, False)
RebeccaStrauch__GISP
do a test for    lyr.isRasterLayer   then use   lyr.replaceDataSource()
To see how I did it, if that doesn't help, look at my script   4_dataSourceRepairX.py , about line #269 in   /blogs/myAlaskaGIS/2015/08/31/python-addin-for-data-inventory-and-broken-link-repair?sr=search&searc...
LloydBronn
I tried this and I'm still getting blank images
for layer in layer_list:
layer_name = layer
 if lyr.dataSource == old_source:
 lyr.replaceDataSource(new_source, "RASTER_WORKSPACE", layer_name, True)
LloydBronn
Just got it to work
I know you said you couldn't find the script for in the addin thread.  You needed to download the .zip file.
