Arcpy - Find data that is not NULL
11899
08-19-2014 10:01 AM
AliciaSoto
I have a shapefile with an attribute table similar to the one below.
NAME
CATDOG
***Johnblackblack
***Pattabby<Null>
Joe<Null>white
First, I want to search for any rows where 'NAME' starts with '***'. Then, from that selection I want to print out data if the 'DOG' column is not <Null>.
Using the table above the output should look like this.
C:\MyDocs\Python>python Animal.py
***John
black
C:\MyDocs\Python>
Here is my code so far
def findAnimal(shapefilePath):
  fields = ('NAME','CAT','DOG')
  cursor = arcpy.da.UpdateCursor(sp,fields)
  for row in cursor:
       nameStr = row[0]
       if nameStr[0:3] == "***":
            if row[2] != None:
                 print row[0]
                 print row[2]
       cursor.updateRow(row)
This is what my code is currently printing out.
***John
black
***Pat
C:\MyDocs\Python>
There is blank row after '***Pat' ,so it looks like it is printing out the <Null> value.
It appears that Line 07 in my code is not working.
Tags (4)
XanderBakker
Esri Esteemed Contributor
I tried to reproduce this and created a shapefile with 3 points and added the attributes as displayed in your example (leaving two fields untouched). You visualize them as <Null>, but a DBF does not have <Null> values as in a geodatabase table.
I change the code to show what it actually prints and it seems to be a single space... When testing against a single space it detects the "<Null>" values.
import arcpy
def findAnimal(shp):
  cursor = arcpy.da.UpdateCursor(shp,fields)
  for row in cursor:
      nameStr = row[0]
            if row[2] != " ":
                print row[0]
                print "'{0}'".format(row[2])
fc = r"C:\Forum\CatsDogs\CatsDogs.shp"
findAnimal(fc)
Kind regards, Xander
IanMurray
Honored Contributor
Hi Alicia,
ArcMap returns a string None for null value in a table instead of a None object.  Change line 7 to if row[2] != "None" and it should work right.
If you are on 10.0 or older, then your method would work, since it return an empty string, see this topic
40913 - How to check for null values in the Field Calculator using Python
AliciaSoto
Hmmmm it's still doing the same thing.
I am using version 10.2
XanderBakker
import arcpy
  for row in cursor:
      nameStr = row[0]
            if row[2] != " ":
                print row[0]
findAnimal(fc)
AliciaSoto
Ah! That's what it was! Thanks!
