ArcPy Feature Class to Feature Class - Name contains invalid charcters
4447
08-03-2018 08:34 AM
Business_IntelligenceSoftware
I have a Feature Class to Feature Class script that is supposed to take a Feature Class (FC) of locations and create a separate FC for each location. However, it keeps giving me the following two errors.
ERROR 000210: Cannot create output E:\arcGIS_Shared\Business Analyst\PotentialCitePackages.gdb\NorthEdmond
ERROR 000354: The name contains invalid characters
Failed to execute (FeatureClassToFeatureClass)
Here is the FC to FC script:
inFeatures = "PythonTest_Geocoded"
fields = ['ObjectID', 'Shape','USER_Center']
with arcpy.da.SearchCursor(inFeatures, fields) as cursor:
    for row in cursor:
        outLocation = r"E:\arcGIS_Shared\Business Analyst\PotentialCitePackages.gdb"
        outFeatureClass = "{0}".format(row[2])
        delimitedField = arcpy.AddFieldDelimiters(env.workspace, "USER_Center")
        expression = delimitedField + " = '{0}'".format(row[2])
        print(expression)
        ## Execute FeatureClassToFeatureClass
        arcpy.FeatureClassToFeatureClass_conversion(inFeatures, outLocation, outFeatureClass, expression)
The output FCs are supposed to be named after their corresponding locations ('USER_Center"). This field contains no invalid characters, as you can see below (I was testing this code on a table with only 3 rows).
Could someone help me figure out what I'm doing wrong/missing?
Thanks.
JoshuaBixby
MVP Esteemed Contributor
Whitespace characters are invalid, and I suspect you have one at the end of your text, i.e., the text is 'NorthEdmond ' instead of 'NorthEdmond' .  Try changing:
outFeatureClass = "{0}".format(row[2].strip())
DanPatterson_Retired
can you print out the expression.
see that capital U suggests it may be making a Unicode character, and I suspect that your path no longer is in raw format and only contains single backslashes.
JoshuaBixby
That was the answer. Thanks for your help!
