arcpy.Exists & arcpy.ListFeatureClasses and wildcards
6690
8
09-09-2015 09:04 AM
BradJones
I have a gdb with around 200 feature classes (waterlines).  I working on a tool that will add the featureclass desired base on an ID number. the featureclasses are named "WATERLINE_<ID NUMBER>_<NAME>".  Example: WATERLINE_123_SPRINGFIELD. Since the only parameter is entered as a 3 digit ID number (string)  I use a wildcard query with arcpy.ListFeatureClasses then use arcpy.Exists to add it to the map.  Some systems don't have waterline data.   This approach isn't working.  If I hardcode the featureclass name into arcpy.Exists it works.  Any ideas are appreciated.
# Import modules
import arcpy
# Set overwrite option
from arcpy import env
env.overwriteOutput = True
# Variables
pws = arcpy.GetParameterAsText(0)
waterlines = "WATERLINE_" + pws + "_*"
wl_layer = "Waterlines " + pws
wl_symb = r"G:\Source Water Protection\PWS_ID_Tool\WATERLINES.lyr"
# Add waterlines
env.workspace = r"G:\WATER_FACILITY\WATERLINES.gdb"
wlFclass = arcpy.ListFeatureClasses(waterlines)
arcpy.AddMessage(wlFclass)  # Print/message statement for results dialog box. Confirms wlFclass is there.
if arcpy.Exists(wlFclass):  # This where it fails.
    arcpy.AddMessage("Waterline data exist for this PWS.")
    arcpy.MakeFeatureLayer_management(waterlines, wl_layer)
    arcpy.ApplySymbologyFromLayer_management(wl_layer, wl_symb)
    newLayer = arcpy.mapping.Layer(wl_layer)
    arcpy.mapping.AddLayer(df, newLayer, "TOP")
else:
    arcpy.AddWarning("No waterline data exist for this PWS.")
Tool results dialog box:
Executing: waterlinestest 465
Start Time: Wed Sep 09 10:36:53 2015
Running script waterlinestest...
[u'WATERLINE_123_SPRINGFIELD']
Completed script waterlinestest...
Succeeded at Wed Sep 09 10:37:27 2015 (Elapsed Time: 33.95 seconds)
WesMiller
You are passing a list where you need a path to "Exists"
import arcpy, os
if arcpy.Exists(os.path.join(workspace,wlFclass[0])):
  print 'yes'
BradJones
this is the code block that works. I needed the for loop to convert the unicode list of one featureclass to a 'regular' string.  thanks for pointing out my stupid mistake.
# Import modules
import arcpy
import os
# Set current mxd and dataframe.
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd, "")[0]
# Add waterlines
for wl in wlFclass:
  wlPath = os.path.join(env.workspace,wl)
  if arcpy.Exists(wlPath):
    arcpy.MakeFeatureLayer_management(wlPath, wl_layer)
  else:
WesMiller
Glad to hear you got it working
FreddieGibson
Honored Contributor
If you're getting the names of the feature classes via arcpy.ListFeatureClasses is there a reason why you'd need to check if they exist? The ListFeatureClasses method would only list the feature classes if they existed.
BradJones
I need ListFeaturecClasses because i'm working from a wildcard querry.  I can't use a wildcard with Exists.
DarrenWiens2
I agree you don't need Exists. You could check the length of the returned list of feature classes to see if any match.
len(wlFclass)
MichaelSouffront
What about replacing the exists function in line 20 with an "if statement". The listfeatures function returns a list and then you could do something like "if len(list) == 1:" or similar
BradJones
Yes, you all are correct.  I didn't think about that!
