arcpy.Describe(relationshipclass) doesn't include key fields.
5077
10
05-19-2011 09:38 PM
MichaelAdornetto
I'm attempting to write a script to read the relationship classes from one geodatabase to another.  These tables have identical feature and object classes.
I should be able to select the relationshipclass in the source, use arcpy.Describe on them and get the parameter I'll need to perform an arcpy.createRelationshipClass_management.  Except the describe does not give me any access Primary / Foreign key information according to the documentation.  Is there away to get these field names because without it I can't recreate the relationship class.
ChrisDiMeo
Hi -
Bumping this thread with a related question.
I'm trying to automate creating relationship classes in python (ArcGIS 10.2.1).  I am able to get most of the information I need via the Describe call as shown in previous posts.  I'd like to get the properties of existing RC's and automate recreating them using the original properties (copy/paste of data not an option).
My issue is that I'm not able to return the Relationship Rules (eg. desc.relationshipRules) as decribed here:
RelationshipClass properties—Help | ArcGIS for Desktop
The documentation is at 10.3 and I am working at 10.2
You can see below that I'm able to return all the properties available for this particular rel class except the Relationship Rules, which, I know exist (also see below).
Has anyone tried to return these relationship rules?  Tried to recreate via python?  Any success?
Chris
