arcpy.DeleteIdentical_management does not delete identicals in ESRI sqlite database.
5844
10
03-11-2022 08:40 AM
MulfordnSons
I'm attempting to use the arcpy method DeleteIdentical_management on an ESRI geometry type sqlite database. However, no records are removed from the database upon running.
When I run delete identical in ArcPro, the identical records are deleted as expected.
Is this a known issue?
Tags (3)
DrewFlater
@MulfordnSons  this bug has been addressed in ArcGIS Pro 3.0.
