arcpy.da.InsertCursor help please
6881
17
02-10-2014 01:08 PM
TonyAlmeida
MVP Regular Contributor
I am trying to create a script that will create a new point feature to a point feature class, but also add the x, y coordinets to "X_Coord" and "Y_Coord" fields. The following code sort of works but only populates the "X_Coord" field. I can't seem to get it to populate the "Y_Coord" field.
import arcpy import pythonaddins import os from arcpy import env  class Add_points(object):     """Implementation for AddPoints_addin.Add_points (Tool)"""     def __init__(self):         self.enabled = True         self.cursor = 3 # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks.     def onMouseDownMap(self, x, y, button, shift):         fc = "points"         workspace = r"C:\Temp\test.mdb"         arcpy.env.overwriteOutput = True          # Start an edit session. Must provide the worksapce.         edit = arcpy.da.Editor(workspace)          # Edit session is started without an undo/redo stack for versioned data         #  (for second argument, use False for unversioned data)         edit.startEditing(True)          # Start an edit operation         edit.startOperation()                  mxd = arcpy.mapping.MapDocument("Current")         df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]         lyr = arcpy.mapping.ListLayers(mxd, "points")[0]          #message = "Your mouse clicked:" + str(x) + ", " + str(y)         #pythonaddins.MessageBox(message, "My Coordinates")                           point = arcpy.Point(x, y)         pointGeometry = arcpy.PointGeometry(point)         row_value = ((x, y))         cursor = arcpy.da.InsertCursor(fc, ("X_Coord", "SHAPE@XY"))         cursor.insertRow(row_value)         """ Create a copy of the PointGeometry objects, by using pointGeometry  """         """  as input to the CopyFeatures tool. """         arcpy.CopyFeatures_management(pointGeometry, r"C:\Temp\test.mdb")          # Stop the edit operation.         edit.stopOperation()          # Stop the edit session and save the changes         edit.stopEditing(True)           arcpy.RefreshActiveView()         pass
I have tried the following but nothing happens, no point feature is created and the "X_Coord" and "Y_Coord" fields are not populated.
import arcpy import pythonaddins import os from arcpy import env  class Add_points(object):     """Implementation for AddPoints_addin.Add_points (Tool)"""     def __init__(self):         self.enabled = True         self.cursor = 3 # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks.     def onMouseDownMap(self, x, y, button, shift):         fc = "points"         workspace = r"C:\Temp\test.mdb"         arcpy.env.overwriteOutput = True          # Start an edit session. Must provide the worksapce.         edit = arcpy.da.Editor(workspace)          # Edit session is started without an undo/redo stack for versioned data         #  (for second argument, use False for unversioned data)         edit.startEditing(True)          # Start an edit operation         edit.startOperation()                  mxd = arcpy.mapping.MapDocument("Current")         df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]         lyr = arcpy.mapping.ListLayers(mxd, "points")[0]          #message = "Your mouse clicked:" + str(x) + ", " + str(y)         #pythonaddins.MessageBox(message, "My Coordinates")          Fields = ["X_Coord", "Y_Coord", "SHAPE@XY"]                          point = arcpy.Point(x, y)         pointGeometry = arcpy.PointGeometry(point)         row_value = ((x, y))         cursor = arcpy.da.InsertCursor(fc, (Fields))         cursor.insertRow(row_value)         """ Create a copy of the PointGeometry objects, by using pointGeometry  """         """  as input to the CopyFeatures tool. """         arcpy.CopyFeatures_management(pointGeometry, r"C:\Temp\test.mdb")          # Stop the edit operation.         edit.stopOperation()          # Stop the edit session and save the changes         edit.stopEditing(True)           arcpy.RefreshActiveView()         pass
and if possible i would like it to populate an auto sequential number based on the last highest number. The field i need the sequential number is a field called the Address_ID field.
JakeSkinner
Esri Esteemed Contributor
Try the following:
with arcpy.da.SearchCursor(fc, ["AddressID"]) as cursor:     for row in cursor:         try:             if "CC" in row[0]:                 list.append(int(row[0].strip("CC")))         except TypeError:             pass del cursor
JakeSkinner
Hi Tony,
Since you are working with a Personal Geodatabase, you will not need to start an edit session.  Try the following:
        arcpy.env.workspace = r"C:\temp\test.mdb"
        fc = "Point"
        list = []
        with arcpy.da.SearchCursor(fc, ["Address_ID"]) as cursor:
            for row in cursor:
                list.append(row[0])
        del cursor
        list.sort()
        Address_ID = list[-1] + 1
        row_values = [(x, y, (x, y), Address_ID)]
        cursor = arcpy.da.InsertCursor(fc, ["X_Coord", "Y_Coord", "SHAPE@XY", "ADDRESS_ID"])
        for row in row_values:
            cursor.insertRow(row)
        del cursor
TonyAlmeida
JSkinns3, Thanks for your repose.
I have tried the following with out any success...
No point was created an X & Y field were not updated and AddressID was not populated.
I noticed that there was no arcpy.pointgeometry, Don't i need this to create a point feature?
On the Address ID field i need the auto sequential to start with CC and be 5 numberic numbers,
example: CC02336
        fc = "points"
        arcpy.env.workspace = r"C:\Temp\test.mdb"
        list = []
            for row in cursor:
                list.append(row[0])
        del cursor
        list.sort()
        del cursor
        pass
JakeSkinner
Open up the Python window in ArcMap and then execute the tool.  Any errors reported?
TonyAlmeida
duh that would help wouldn't...my bad.
I get this error.
  File "C:\Users\talmeida\AppData\Local\ESRI\Desktop10.1\AssemblyCache\{BB229966-100D-4482-A3FE-B298BD262597}\AddPoints_addin.py", line 30, in onMouseDownMap
    for row in cursor:
RuntimeError: Too few parameters. Expected 1.
with this code
import arcpy
import pythonaddins
import os
    def __init__(self):
        self.enabled = True
        edit = arcpy.da.Editor(env.workspace)
        fc = "points"
        list = []
            for row in cursor:
                list.append(row[0])
        del cursor
        list.sort()
        del cursor
        pass
JakeSkinner
Do you have the field 'Address_ID' in the feature class?
TonyAlmeida
actually it's AddressID. my bad...
I mad the changes to replace the Address_ID to AddressID and i am getting the following
  File "C:\Users\talmeida\AppData\Local\ESRI\Desktop10.1\AssemblyCache\{BB229966-100D-4482-A3FE-B298BD262597}\AddPoints_addin.py", line 36, in onMouseDownMap
    AddressID = list[-1] + 1
TypeError: coercing to Unicode: need string or buffer, int found
JakeSkinner
Since AddressID is a text field, you will have to convert it to an int, add 1, then convert it back to a string.  Replace:
with:
AddressID = int(list[-1].strip('CC0')) + 1
AddressID = 'CC0' + str(AddressID)
TonyAlmeida
interesting i was going about it the wrong way.
The auto sequential ends at CC09, even after adding more points the rest are CC09.
With the current code the AddressID field is populated like this CC01, CC02.
I need them have leading zeros of five like so. They don't all start at CC00001
CC00001, CC00002, CC00010, CC00123, CC01234, CC56560
Is this possible and if so how?
Thanks again for all your help!
JakeSkinner
In your case, you need every added point to be greater than the largest AddressID, i.e. CC56560?  If that is the case, what is the larget AddressID?
Or, is this tool going to be used for multiple feature classes, and the AddressID varies? i.e. CC00100 is the largest for one feature class, CC032232 is the largest for another feature class
