arcpy.Buffer_analysis error
3016
08-29-2011 06:23 PM
VadivelanPalanichamy
I am new in Python scripting..
I have downloaded samples from esri site.
buffer = arcpy.Buffer_analysis(roads, "in_memory/buffer", "1000 Feet"), "", "", "ALL"  )
A syntax error is shown in the above.  Any idea/suggestions on this......
StacyRendall1
Yo,
you have two close brackets ), but only one open bracket (... This is invalid syntax, hence the syntax error.
The number of brackets need to balance, I presume you actually wanted this:
MathewCoyle
Honored Contributor
Yo,
And I presume you meant this?
buffer = arcpy.Buffer_analysis(roads, "in_memory/buffer", "1000 Feet", "", "", "ALL" )
StacyRendall1
True, true...
