arcpy.AssignDefaultToField_management not assiging a default to a field
1817
04-28-2023 07:10 AM
danieloccasionally
When originally setting this up I solved this problem ... somehow, now I can't recall how for the life of me.
After adding some fields to a file geodatabase feature class (TWP+"_RIGHTS"), I create and apply domains to three of the fields. The default is supposed to be "Choose", yet it just shows "<Null>". Any ideas how the problem can be corrected?
 # create and set domains to fields
arcpy.env.workspace = projectfilepath + county+"_"+TWPfileGDB
RIGHTS = TWP + "_RIGHTS"
# Set local parameters
gdb = projectfilepath + county+"_"+TWPfileGDB
inFeatures = RIGHTS
default_value = 0
domName = "OpCo_Domain"
domain_description = "OpCo Choices"
inField = "OpCo"
# Process: Create the coded value domain
existingDomains = arcpy.da.ListDomains(gdb)
domain_names = [i.name for i in existingDomains]
if domName in domain_names:
    print(domName + " already exists")
    arcpy.management.AssignDomainToField(inFeatures, inField, domName)
    arcpy.AssignDefaultToField_management(inFeatures, inField, default_value)
else:
    print("creating domain " + domName)
    arcpy.management.CreateDomain(gdb, domName, domain_description, "TEXT", "CODED")
    domDict = {"0": "Choose", "1": "METC", "2": "ITCT"}
    for code in domDict:
        arcpy.management.AddCodedValueToDomain(gdb, domName, code, domDict[code])
    # Process: Constrain the material value of distribution mains
domName_2 = "RightsType_Domain"
domain_description_2 = "RightsType Choices"
inField_2 = "RightsType"
if domName_2 in domain_names:
    print(domName_2 + " already exists")
    arcpy.management.AssignDomainToField(inFeatures, inField_2, domName_2)
    arcpy.AssignDefaultToField_management(inFeatures, inField_2, default_value)
else:
    print("creating domain " + domName_2)
    arcpy.management.CreateDomain(gdb, domName_2, domain_description_2, "TEXT", "CODED")
    domDic_2 = {"0": "Choose", "1": "Easement", "2": "Fee", "3": "License"}
    for code in domDic_2:
        arcpy.management.AddCodedValueToDomain(gdb, domName_2, code, domDic_2[code])
domName_3 = "Type_of_Use_Domain"
domain_description_3 = "Type_of_Use Choices"
inField_3 = "Type_of_Use"
if domName_3 in domain_names:
    print(domName_3 + " already exists")
    arcpy.management.AssignDomainToField(inFeatures, inField_3, domName_3)
    arcpy.AssignDefaultToField_management(inFeatures, inField_3, default_value)
else:
    print("creating domain " + domName_3)
    arcpy.management.CreateDomain(gdb, domName_3, domain_description_3, "TEXT", "CODED")
    domDict_3 = {"0": "Choose", "1": "Full T-Line", "2": "Substation", "3": "Railroad", "4": "Overhang Only",
                "5": "Veg Management Only", "6": "Access", "7": "Other"}
    for code in domDict_3:
        arcpy.management.AddCodedValueToDomain(gdb, domName_3, code, domDict_3[code])
print("Completed"+" "+time.strftime("%x" +" "+ "(%a)" +" "+ "at"+" "+"%I:%M"))
danieloccasionally
Ah, I corrected my code to reference each domains' dictionary ! Thank you @DonMorrison1
field = "OpCo"
expression = 0
arcpy.management.CalculateField(RIGHTS, field, expression, "", "", "", "ENFORCE_DOMAINS")
field = "RightsType"
expression = 0
field = "Type_of_Use"
expression = 0
DonMorrison1
I believe that the defaults are not applied to existing records in your feature class, but the are applied only to new records being added.  To update existing records you could run arcpy.management.CalculateField
danieloccasionally
@DonMorrison1  I'm not sure what you mean! I'm getting an error.
expression = "!Type_of_Use!.replace(' ', 'Choose')"
Here's the error:
  File "<expression>", line 1, in <module>
AttributeError: 'NoneType' object has no attribute 'replace'
danieloccasionally
field = "OpCo"
expression = 0
expression = 0
expression = 0
