Arcpy Append - How to load a .fieldmap file
1462
10-23-2024 12:05 PM
CW-GIS
Good afternoon,
I have a standard append script, how could I just load the a fieldmap file that I saved?
Append = arcpy.management.Append(inputs=[feature_class], target=hosted_feature, schema_type="NO_TEST", field_mapping="***Load FieldMap File***")
HaydenWelch
MVP Regular Contributor
Append takes FieldMappings objects that can be created using a .loadFromString:
import arcpy
import os
def load_fieldmap(path: os.PathLike) -> arcpy.FieldMappings:
    with open(path, 'r') as fieldmap:
        return arcpy.FieldMappings().loadFromString(fieldmap.read())
    inputs=["C:/path/to/input.gdb/input"],
    target="C:/path/to/output.gdb/output",
    field_mapping=load_fieldmap("C:/path/to/fieldmap.fieldmap")
JakeSkinner
Esri Esteemed Contributor
Hi @CW-GIS can you post an example of your fieldmap file?
Also, have you seen the example of using Field Mappings in the following example?
HaydenWelch
import arcpy
import os
