Arcpy 3.2.2 Polygon getpart issue
1831
02-23-2024 08:10 AM
MarceloCesarTorres
I'm trying to get polygon parts  but I get an exception:
File "c:\Users\Mtorres\source\repos\FFP-ArcGISPro-Project\src\Public Inspection\Python Toolboxes\PublicInspectionArcGIS\Centerline.py", line 73, in _extract_parts_from_input_geometry
part = geometry.getPart(index)
File "c:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\arcobjects\arcobjects.py", line 1331, in getPart
return convertArcObjectToPythonObject(self._arc_object.GetPart(*gp_fixargs(args)))
RuntimeError: DescribeGeometry: Error in getting part from geometry
The script runs on ArcGIS Pro v3.2.2. Next script code fragment where I make the call:
        parts = []
        geometry = self.input_geometry
        if geometry.isMultipart :
            part_range = range(0, self.input_geometry.partCount)
        else :
            part_range = range(0, 1)
        for index in part_range :
            parts.append(part)
        return parts
I run the same code on ArcGIS Pro 3.1but the exception never happens.
Is there an error with last version of arcpy?
Marcelo
Tags (3)
MarceloCesarTorres
Thanks for your answer, I'm working with a FileGeodatabase. But  I realize that there was a issue with geometries at the feature class: Shape Areas were negatives.
Then I used "Repair Geometries" Tool to fix geometries, and everything start to works fine.
I get this output from tool:
Kepa
by Esri Contributor
Hi @MarceloCesarTorres,
I'm not able to reproduce your error in 3.2.2 nor in 3.1.3, at least in my personal environment (FileGDB and PostgreSQL -ST_Geometry). Are you working in an enterprise geodatabase? Shapefiles? In memory?
I'd perform a geometry check just in case and make sure you are working with proper geometries.
Regards,
MarceloCesarTorres
