ArcPro Script Tool parameter for a variety of file types
2286
9
11-12-2025 08:37 AM
JaredPilbeam2
import arcpy,os
# delete old zips
def delete_old_parcels_zip(oldzip, workspace_folder):
    arcpy.env.workspace = workspace_folder
    # r=root, d=directories, f=files
    for root, directories, files in os.walk(workspace_folder):
        for file in files:
            if file.endswith(oldzip): #.endswith accepts a tupule
                #delete existing zips from folder
                print("old zips deleted: {}".format(file))
                arcpy.AddMessage("old zips deleted: {}".format(file))
                arcpy.Delete_management(file)
if __name__ == "__main__":
    #name of zip file with extension
    oldzip = arcpy.GetParameterAsText(0)
    # output folder
    workspace_folder = arcpy.GetParameterAsText(1)
    # delete
I'm having trouble getting this script to work as a script tool. It works fine as a stand-alone. I've tried a number of things in Pro Catalog Toolboxes:
  1. Properties > Execution panel > embedded
  2. Properties > Execution panel > external script
  3. Properties > Parameter 0: Data Type > File > Filter File (zip; shp)
  4. Properties > Parameter 0: Data Type > Shapefile
  5. Properties > Parameter 0: Data Type > Folder
  6. Properties > Parameter 1: Data Type > Workspace
It doesn't throw any errors. But it produces no results. Basically, the tool is supposed to find a file based on user input and in the workspace and delete it. Note: I'm after learning to use if __name__ == "__main__" in a script tool.
JaredPilbeam2
@DuncanHornby @TonyAlmeida
It worked with the arcpy.GetParameter() function and the Data Type parameter set to String. I used the index 0. I was able to run the tool numerous times on the following files and it deleted all of them: *.zip, *.shp, *.png, *.jpeg. So:
    oldzip = arcpy.GetParameter(0)
    # output folder
    # delete
DuncanHornby
MVP Notable Contributor
OK when you run it does it print your "old zip files deleted message" but nothing happens?
JaredPilbeam2
No, no print messages.
DuncanHornby
OK what would be genuine examples of the two input parameters?
Also setting parameter zero to be a File AND  a Shapefile AND a Folder makes no sense to me, should it not simply be File with your filter set?
  1. Properties > Parameter 0: Data Type > File > Filter File (zip; shp)
  2. Properties > Parameter 0: Data Type > Shapefile
  3. Properties > Parameter 0: Data Type > Folder
JaredPilbeam2
Two examples of input:
oldzip = 'WillCounty_Street.zip'
workspace_folder = r'C:\Users\jpilbeam\test'
Thanks for asking. So, the end-user of this tool would input files to delete in the first parameter. The files in the workspace folder could be either a *.zip, *.shp or *.pdf. What I was pointing out was the separate scenarios I've tried . As in, what I've tried was:
- setting the Data Type to File
- setting the Data Type to File, and File Filter to zip; shp
- setting the Data Type to Shapefile
- setting the Data Type to folder. --This didn't make much sense, but i tried it anyway.
TonyAlmeida
MVP Regular Contributor
try,
        for file in files:
            if file == oldzip or file.endswith(oldzip):
                file_path = os.path.join(root, file) #should pass the full path
                print(f"Old zip deleted: {file_path}")
                arcpy.AddMessage(f"Old zip deleted: {file_path}")
                arcpy.Delete_management(file_path)
                deleted_files += 1
JaredPilbeam2
@TonyAlmeida
Thanks, that works on its own (without += operator) but embedded in the script tool with the same input as before it runs but doesn't delete and no print statements in tool.
I believe the issue lies with the script tool data type parameter for file. I'm going to concentrate on that.
Tool interface:
JaredPilbeam2
    # output folder
    # delete
TonyAlmeida
I was just getting ready to indicate the parameter 0 has to be GetParameterAsText and as to be string.  I tested it on my end.
JaredPilbeam2
Nice. Yeah, it doesn't make a difference if parameter 0 is GetParameter() or GetParameterAsText(). Both work. It's only the Data Type that needed changed.
