I am having difficulty with python parser label function to replace null values with "Unknown Plan" and leave everything else as is. The Unknown Plan is not displaying in the map label.
I have the following:
<SPAN class="keyword token">def</SPAN> FindLabel <SPAN class="punctuation token">(</SPAN> <SPAN class="punctuation token">[</SPAN>PLAN<SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>PLAN<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">is</SPAN> None<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="string token">"Unknown Plan"</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">[</SPAN>PLAN<SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Any idea it is not working ?
