ArcGIS Pro M value tools: Is "Set Direction As M" in arcpy?
1373
04-20-2023 02:10 PM
DanielWebb
ArcGIS Pro has tools for working with M values. Are these functionalities available in arcpy?
by Anonymous User
Not applicable
Think you'll have to do it manually with a cursor and extracting the m from the point.  Stealing a post from SO
lyr = r"C:\Users\...\Default.gdb\TEST_ROUTE"
fields = ['SHAPE@']
with arcpy.da.UpdateCursor(lyr, fields) as cursor:
    for row in cursor:
        partslist = []
        partlist = []
        array = None
        feat = row[0]
        partnum = 0
        # Count the number of points in the current multipart feature
        partcount = feat.partCount
        pntcount = 0
        # Enter while loop for each part in the feature (if a singlepart feature
        # this will occur only once)
        while partnum < partcount:
            part = feat.getPart(partnum)
            pnt = part.next()
            # Enter while loop for each vertex
            while pnt:
                pntcount += 1
                if not numpy.isnan(pnt.M):
                    partlist.append(arcpy.Point(pnt.X, pnt.Y, pnt.Z, pnt.M / 1000))
                pnt = part.next()
                # If pnt is null, either the part is finished or there is an
                # interior ring
                if not pnt:
                    pnt = part.next()
            partslist.append(arcpy.Array(partlist))
            array = arcpy.Array(partslist)
            partlist = []
            partnum += 1
        polylinefeat = arcpy.Polyline(array)
        row[0] = polylinefeat
        cursor.updateRow(row)
by Anonymous User
Not applicable
fields = ['SHAPE@']
    for row in cursor:
        partslist = []
        partlist = []
        array = None
        feat = row[0]
        partnum = 0
        pntcount = 0
            pnt = part.next()
            while pnt:
                pntcount += 1
                pnt = part.next()
                # interior ring
                if not pnt:
                    pnt = part.next()
            partlist = []
            partnum += 1
DanielWebb
This seems to do what I want. Thank you!
