Arcgis online sign in box prevents from publishing service using ArcPy
2872
05-28-2014 10:36 PM
SergeyBurmisov
I am publishing a local ArcGIS Server Map service using ArcPy script (script follows below) (running on that very server).
Every time I call arcpy.UploadServiceDefinition_server() arcgis online sign in dialog box pops up and execution is paused until I reject to sign in.
While acceptable in interactive mode, this totally prohibits running the script in unattended mode.
How can I disable the dialog and why does it pop up at all?
Server version 10.2.2, layers in the mxd have a registered connection to SQL geodatabase. Publishing from ArcMap works OK with no errors or warnings.
arcpy.mapping.CreateGISServerConnectionFile("PUBLISH_GIS_SERVICES",
                                            outDir,
                                            outName,
                                            serverUrl,
                                            "ARCGIS_SERVER",
                                            False,
                                            outDir,
                                            usr,
                                            pwd,
                                            "SAVE_USERNAME")
arcpy.mapping.CreateMapSDDraft(mapDoc, sddraft, service, 'ARCGIS_SERVER', outName, False, None, 'summary', 'tags')
arcpy.StageService_server(sddraft, sd)
arcpy.UploadServiceDefinition_server(sd, outName)
[ATTACH=CONFIG]34171[/ATTACH]
JasonScheirer
The sign-in dialog should never appear when running as a Python script. This is a bug. Please contact support.
AdamMarinelli
Hello @Surgey Burmisov, did you every find a resolution to the sign-in box appearing while running a python script that calls arcpy.UploadServiceDefinition_server()?
SergeyBurmisov
We never actually found a _solution_ to the problem, but we did perform multiple reinstalls of different ArcGIS Server versions, and it seemed like a floating bug less likely to appear on new installations.
So we reached some point when all production servers were running OK (no dialog box pops up), and settled on that infirm ground, hoping never to see the problem again
AdamMarinelli
Okay well I appreciate the information.  I did come across this bug which was addressed at 10.2 and might explain the behaviour
NIM-088658
When background processing is enabled, the Upload Service Definition tool makes HTTP requests to 'http://www.arcgis.com/arcgisuris.xml' when it is run.
