ArcGIS crashing after interacting any Python related tool
4955
11
10-18-2016 03:35 AM
SOVANHALDER
I have ArcGIS 10.2 on a 64bit Windows 7 machine. I had two versions of Python
1. 2.7.4 64 bit stand alone
2. 2.7.5 32 bit with ArcGIS
While running any python script I found conflict between two versions so I uninstalled the 64 bit python. Though the scripts are running fine ArcMap is crashing while accessing any python related tool.
Kindly help on it.
DanPatterson_Retired
Use Numpy... you have access to it!!  Panda uses numpy as its base for most stuff so if you need to read a feature class and do stuff with a column, or two or a whole featureclass, you are good to go.  I have dozens of posts on my blog dealing with working with numpy.
SandeepKumar11
Thank you sir i will read from your blog.
