ArcGIS API for Python Map Export Error
1598
04-13-2023 02:05 PM
UnsungHer0z
I am creating a basic map following the instructions from the ArcGIS API for Python tutorial (see link below).
https://developers.arcgis.com/python/guide/part5-saving-updating-and-embedding-map-widget/
When using the export_to_html method I get a bad escape \u and I cannot export the map. Is there a resolution to this error? It seems to me this error is related to this stack overflow question:
https://stackoverflow.com/questions/54330673/how-to-fix-error-bad-escape-u-at-position-0
Code (replaced API key and file path):
gis = GIS(api_key='my key')
map1 = gis.map('USA')
map1.export_to_html('file path')
Error:
Package Versions:
Python - 3.7.1
ArcGIS - 2.1.0.3
UnsungHer0z
That did not solve the issue, but I did look again and it ended up being an error with the ipywidgets version. I updated to 7.7.5 (anything after version 8 causes more errors) and now it works. I can successfully export the map as an html file but now I am running into another issue where the map file is blank when I open it. Not sure if I should create another post or continue with this one for this issue.
DavidPike
MVP Notable Contributor
Have you got any backlashes in your arguments?  Error seems to be related to them.  Maybe use a raw string for your filepath r'C:\Stuff\I Love GIS'
UnsungHer0z
