ArcGIS 10.0: Python Window - Try to Create 3 polygons, but no 3rd polygon showed up
1188
09-27-2012 12:22 PM
ScottChang
Hi all,
I created the following ArcPy-Python script:
# ===== newWritingGeometries3Polygons in PythonWin 2.6.5 ========
# Create a new polygon feature class using a text file of coordinates.
#   Each coordinate entry is semicolon delimited in the format of ID;X;Y
# Import ArcPy and other required modules
import arcpy
from arcpy import env
import fileinput
import string
import os
env.overwriteOutput = True
# Get the coordinate ASCII file
#infile = arcpy.GetParameterAsText(0)
infile = r"C:\TEMP\WritingGeometries\WritingGeometries_3features.txt"
# Get the output feature class
# fcname = arcpy.GetParameterAsText(1)
fcname = r"C:\TEMP\BS_Test.gdb\Polygons_fc"
# Get the template feature class
# template = arcpy.GetParameterAsText(2)
template = r"C:\TEMP\BS_Test.gdb\bsInFeatureClass"
try:
   # Create the output feature class
   arcpy.CreateFeatureclass_management(os.path.dirname(fcname),
                                       os.path.basename(fcname),
                                       "Polygon", template)
   # Open an insert cursor for the new feature class
   cur = arcpy.InsertCursor(fcname)
   # Create an array and point object needed to create features
   polygonArray = arcpy.Array()
   pnt = arcpy.Point()
   # Initialize a variable for keeping track of a feature's ID.
   ID = -1
   for line in fileinput.input(infile): # Open the input file
      # set the point's ID, X and Y properties
      pnt.ID, pnt.X, pnt.Y = string.split(line,";")
      print pnt.ID, pnt.X, pnt.Y
      if ID == -1:
         ID = pnt.ID
      # Add the point to the feature's array of points
      #   If the ID has changed, create a new feature
      if ID != pnt.ID:
         # Create a new row or feature, in the feature class
         feat = cur.newRow()
         # Set the geometry of the new feature to the array of points
         feat.shape = polygonArray
         # Insert the feature
         cur.insertRow(feat)
         polygonArray.removeAll()
      polygonArray.add(pnt)
      ID = pnt.ID
   # Add the last feature
   feat = cur.newRow()
   cur.insertRow(feat)
   lineArray.removeAll()
   fileinput.close()
   del cur
   arcpy.SetParameterAsText (0, fcname) # newly added 18Sept2012, per Barbara S.
except Exception as e:
   print e.message
I executed the script and I just got 2 polygons - see the attached file for details.  Please kindly help and tell me why the 3rd polygon failed to show up ( I believe the following code staments do not work:
   feat = cur.newRow()
   cur.insertRow(feat)
Scott Chang
ScottChang
I forgot to attach the text file of ID, and X,Y-coordinates for the 3 polygons to be created.
Please see the attached file in this thread for the text file of ID, and X,Y-coordinates for the 3 polygons to be created.
Scott Chang
JakeSkinner
Esri Esteemed Contributor
Hi Scott,
Remove the extra lines after the last line in the text file and it should work.
ScottChang
Hi Jake,
Thank you very much for your valuable response.
The extra lines/space after the last line of input data is a big devil and wasted me so much time!!!
Thanks again,
Scott Chang
