ApplySymbologyFromLayer not working
2066
6
10-24-2022 05:01 PM
Katie_Clark
MVP Regular Contributor
I am attempting to write a map automation script for ArcGIS Pro. Taking things one step at a time, and so far the script successfully creates some layers, adds them to a specified geodatabase, and then adds them to the current map in the Pro project. I then need to apply symbology to the layers, which I am trying to do using arcpy.ApplySymbologyFromLayer_management. Here is a snippet from my code:
aprx = arcpy.mp.ArcGISProject("CURRENT")
m = aprx.listMaps("Primary Map Frame")[0]
m.addDataFromPath(f"{out_gdb}\BackgroundPointsFiltered_{dateTag}")
m.addDataFromPath(f"{out_gdb}\CompliancePointsFiltered_{dateTag}")
m.addDataFromPath(f"{out_gdb}\WorkLocationPointsFiltered_{dateTag}")
in_layer = m.listLayers()[2] # The background points layer that was just added to the map frame
in_symbology_layer = r"R:\gis\.....BackgroundPointsFiltered.lyrx"
arcpy.ApplySymbologyFromLayer_management(in_layer, in_symbology_layer)
I've tried many other variations that I've seen from hints on stackexchange and geonet, but none have seemed to work for me. The script doesn't fail, but the symbology doesn't update.
What am I doing wrong here? Or is this somehow still related to a bug that I've seen mentioned related to this tool?
I'm using ArcGIS Pro v3.0.2
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
DanPatterson
This bug
BUG-000116527: ApplySymbologyFromLayer in a Python script in ArcGIS.. (esri.com)
BUG-000108497: Running the Apply Layer Symbology tool as a script i.. (esri.com)
The latter has the clever solution
Close and re-open the project.
In either event, subscribe to the bugs so they get elevated and addressed since there are number of issues with this for not only vector geometry but raster symbology
... sort of retired...
Katie_Clark
Thanks for the response, Dan. I subscribed to both of those bugs.
However, I tried the workaround of closing and reopening the project and the symbology still hadn't been applied to the layer. Any ideas of what else could be causing it?
Best,
Katie
DanPatterson
Not sure, but checking to see if it does it manually through the interface would be my first check.
Often when "one would expect" the symbology to be updated for the same geometry type, I have often been surprised by expectations
DonMorrison1
I have some old code where ApplySymbologyFromLayer did work (not used anymore so I can't test it). You can see the the layer was created differently, I used a .lyr file,  and I specify the layer title as the first parameter.
arcpy.MakeFeatureLayer_management(in_features, layer_title, where_clause)
symbology_fn = r"xxxxxx.lyr"
arcpy.ApplySymbologyFromLayer_management (layer_title, symbology_fn)
Jeff-Reinhart
These bugs are from 2017/2018 and they still are not fixed. Close/open the project is not an option in my stack (Azure Remote App served Pro project). Disappointed.
Sveouu
Very surprised to find this BUG from 2018 is still not resolved;  Using ArcGIS Pro 3.4 in 2026.
