Appending raster properties to table format (csv or text)
2601
09-06-2016 02:01 AM
ShouvikJha
I having trouble to save raster statistics value into csv or text format. Below is my working code. Below code only print the raster statistics value, but i am interested to save the output value to text or csv format.
I appreciate any help you can provide on the crucial bottom code.
Thank you
import arcpy
arcpy.env.workspace = r"D:\2008A"
rasterList = arcpy.ListRasters()
for raster in rasterList:
 rasterObj = arcpy.Raster(raster)
 print raster
bands = arcpy.GetRasterProperties_management(raster, "MEAN")
 print "MEAN VALUE: %s" %bands
bands = arcpy.GetRasterProperties_management(raster, "STD")
 print "STANDARD DEV: %s" %bands
bands = arcpy.GetRasterProperties_management(raster, "MINIMUM")
 print "MIN VALUE: %s" %bands
bands = arcpy.GetRasterProperties_management(raster, "MAXIMUM")
 print "Max VALUE: %s" %bands‍‍‍‍‍‍‍‍‍‍‍‍‍‍
FC_Basson
import arcpy
csvfile = open(r'D:\2008A\rasters.csv','w')
    csvfile.write(str(raster) + "\n")
    csvfile.write("MEAN VALUE: %s \n" %bands)
    csvfile.write("STANDARD DEV: %s \n" %bands)
    csvfile.write("MIN VALUE: %s \n" %bands)
    csvfile.write("Max VALUE: %s \n" %bands)
csvfile.close()
FC_Basson
import arcpy
csvfile.close()
ShouvikJha
FC Basson‌. Thank you very much. Code perfectly working
FC_Basson
You can also add another line break after each raster statistics loop to make it more readable i.e. csvfile.write("\n")
ShouvikJha
FC Basson‌, yes exactly ,Good suggestion , i have added the line
