Append_management and data within a list
1380
05-11-2012 10:57 AM
JasonKolbow
Hello all,
I have a KML file that I've parsed through to obtain some values that get returned as a list. I need this list to append into a table, all as one row entry.  As it stands currently I'm unable to append data unless its one entry from the list in its own row within a table.  I hope that you guys can shed some insight on this issue.  Near the top you'll find a nested loop for my list called "record" - I've commented out 2 lines of code because I'm a bit stuck on what to do at this point.  I've attached the KML file in Text Form if you want to try this on your local PC's.
import arcpy  file = r"\\finch\gis\temp\kml\DowsonRansom.kml" f = open(file, 'r') dest = r'C:\Documents and Settings\jmkolb\Desktop\test.gdb\TEST' recordNumber = 0  for line in f:     # Strips leading and trailing spaces from file lines     r = line.strip()      # Checks line integrity for < to start string, assigns variable t1     t1 = r.startswith("<")     t2 = r.endswith(">")      if line.find("<Placemark>") > 0:         if recordNumber <> 0:             record = [Description, Target, RowSpacing, StandCount, Name, CoordinateX, CoordinateY] #photolist]             # Process: Create Table             #arcpy.CreateTable_management(in_memory, "tbl", "'C:\\Documents and Settings\\jmkolb\\Desktop\\test.gdb\\TEST'", "")             # Process: Append             #arcpy.Append_management("record", dest, "NO_TEST", "Name \"Name\" true true false 255 Text 0 0 ,First,#,record[4],Name,-1,-1;FolderPath \"FolderPath\" true true false 255 Text 0 0 ,First,#;SymbolID \"SymbolID\" true true false 4 Long 0 0 ,First,#;AltitudeMode \"AltitudeMode\" true true false 2 Short 0 0 ,First,#;Snippet \"Snippet\" true true false 268435455 Text 0 0 ,First,#;PopupInfo \"PopupInfo\" true true false 268435455 Text 0 0 ,First,#;Description \"Description\" true true false 50 Text 0 0 ,First,#,record[0],Description,-1,-1;Target \"Target\" true true false 50 Text 0 0 ,First,#,record[1],Target,-1,-1;Row_Spacing \"Row_Spacing\" true true false 50 Text 0 0 ,First,#,record[2],Row_Spacing,-1,-1;Stand_Count \"Stand_Count\" true true false 50 Text 0 0 ,First,#,record[3],Stand_Count,-1,-1;Lat \"Lat\" true true false 8 Double 0 0 ,First,#,record[5],Lat,-1,-1;Long \"Long\" true true false 8 Double 0 0 ,record[6],Long,-1,-1", "")          CoordinateX =  ""         CoordinateY =  ""         Name = ""         Description = ""         Target = ""         RowSpacing = ""         StandCount = ""         photolist = []         recordNumber = recordNumber + 1      Attribute = ""     Value = ""      # Checks to see if the line starts and ends with Open and Closing Karrots     if t1 == True and t2 == True:         if line.find("<SimpleData name") > 0:             # Looks for "name=", and pulls the entry between name=" and "><, and its corresponding value from the CDATA tag             Attribute = line[line.find("name=") + 6: line.find("><")-1]             Value = line[line.find("CDATA")+6:line.find("]]></SimpleData>")]             if Attribute == "Description":                 Description = Value             elif Attribute == "Target":                 Target = Value             elif Attribute == "Row Spacing":                 RowSpacing = Value             elif Attribute == "Stand Count":                 StandCount = Value             elif Attribute == "PDFMaps_photos":                 photolist = line.split('"')                 # Sorts the list                 photolist.sort()                 # Reverses sort so Field Name is in position 0                 photolist.reverse()                 # Returns list                 photolist = photolist[:photolist.index('PDFMaps_photos')]                 # Sorts list so Field Name is in position 0                 photolist.sort()                 Attribute = photolist         # Looks for Coordinate tag  in the line         if line.find("<coordinates>") > 0:             # Grabs the value after <coordinates>, splitting by comma for a list             CoordinateX =  line[line.find("<coordinates>")+13:].split(",")[0]             # Grabs the 2nd value in the list after finding <coordinates>             CoordinateY =  line[line.find("<coordinates>")+13:].split(",")[1]             #print "X:",CoordinateX, "Y:",CoordinateY            # Looks for <name> in the line         if line.find("<name>") > 0:             # Pulls the value between CDATA[ and ]]></name>             Name = line[line.find("CDATA")+6:line.find("]]></name>")]             #print "NAME",Name      else:       # Looks for <SimpleData name value within line that doesn't close with >       if line.find("<SimpleData name") > 0:         midline = " "         # Looks in the open line to find the value between name= and ><, and prints it         Attribute = line[line.find("name=") + 6: line.find("><")-1]         # Finds the value for the attribute just found in above line         multiLines = line[line.find("CDATA")+6:].strip()       # Looks in the open line to find the close karrot       elif line.find("]]></SimpleData>") > 0:         multiLine = multiLines + midline.replace('\n'," ") + line[:line.find("]]></SimpleData>")]         #Decision to use multiple line (2 or less) or multiLines (3 or more) for Description         if len(multiLine) > len(multiLines):             Description = multiLine         else:             Description = multiLines       # For all lines that do not have an open or close karrot       else:         midline = midline + line f.close()
JasonKolbow
I ended up using a insert cursor to fix my issue. formatting for it is at the following link Search Cursor Help  With this I was able to insert an entire list into one row.
KimOllivier
Honored Contributor
Try the elementTree module for handling XML. It is much easier to use to extract out elements into Python dictionaries and lists.
JasonKolbow
Thanks for the suggestion Kim. At this point, I've got no issue with having the data I need extracted from the XML. My issue is with taking that data and utilizing an Append of some kind to insert all of the data into one row of a feature or table.  Since there can be multiple JPG items within the XML tags, I've had to make a list, within a list to extract those values.  That being said, would you think I could use an alternative method to push this data into a feature class or table with the arcpy toolset?
Thanks again for your answer, I'll give it a shot with other XML files I may receive.
Jason
JasonKolbow
