Append feature classes using Python
10373
16
07-05-2018 06:53 AM
EdwardGlover1
I have 5 point feature classes that I am trying to append into a point feature class.  I get the following error when I attempt to run the code shown below:
Failed to execute. Parameters are not valid.
ERROR 000338: Inputs must be either all Feature Classes, Tables or Rasters; not mixed.
Failed to execute (Append).
I can run the append successfully when using the Append tool in Desktop.  I am at a loss as to why the code throws the error.  Any insight would be very much appreciated.
# Import arcpy module
import arcpy
import os
SDE = r'C:\Development\py1\gis@GISDEV02 frt (emadb51 DC) - VegD2.sde'
# Set local variables
FC_Inven = os.path.join(SDE, 'GIS.VegD_Inventory')
FC_Unit = os.path.join(SDE, 'GIS.VegD_Unit_Inventory')
FC_Hrly2 = os.path.join(SDE, 'GIS.VegD_Hourly_Inventory')
FC_Hrly = os.path.join(SDE, 'GIS.VegD_Hourly')
FC_Flat = os.path.join(SDE, 'GIS.VegD_FlatRate')
FC_Matrix = os.path.join(SDE, 'GIS.VegD_Matrix')
schemaType = "NO_TEST"
fieldMappings = ""
subtype = ""
try:
    # Process: Truncate Table
    arcpy.TruncateTable_management(FC_Inven)
    # Process: Append the feature classes into the empty feature class
    arcpy.Append_management('FC_Unit; FC_Hrly2; FC_Hrly; FC_Flat; FC_Matrix', FC_Inven, schemaType,    fieldMappings, subtype)
except Exception as err:
print(err.args[0])
EdwardGlover1
Unfortunately, I get the same error message when I try this approach as well.
DarrenWiens2
The help example uses a list for the feature classes, not a delimited string.
Append—Data Management toolbox | ArcGIS Desktop
DanPatterson_Retired
DarrenWiens2
Ah, so it was. I thought you meant comma-delimited string. You can't make a list any other way
EdwardGlover1
I get the same ERROR 000338 when I copied the feature classes to a fgdb and modified the code to reference it and run it.  I then tried using the Append tool and navigating to the fcs within the tool to add them with their entire fgdb path - it ran successfully.  I went to the results, right-clicked and copied as code snippet.  I took the input and target syntax from that code and replaced my append input and target parameters with it and ran the code - it worked successfully.  I repeat these steps with a database connection and was successful.
arcpy.Append_management("'C:/Development/py1/gis@GISDEV02 frt (emadb51 DC) - VegD2.sde/GIS.VegD_FlatRate';'C:/Development/py1/gis@GISDEV02 frt (emadb51 DC) - VegD2.sde/GIS.VegD_Hourly';'C:/Development/py1/gis@GISDEV02 frt (emadb51 DC) - VegD2.sde/GIS.VegD_Matrix';'C:/Development/py1/gis@GISDEV02 frt (emadb51 DC) - VegD2.sde/GIS.VegD_Hourly_Inventory';'C:/Development/py1/gis@GISDEV02 frt (emadb51 DC) - VegD2.sde/GIS.VegD_Unit_Inventory'", "C:/Development/py1/gis@GISDEV02 frt (emadb51 DC) - VegD2.sde/GIS.VegD_Inventory", schemaType,    fieldMappings, subtype)
I still don't know why when I attempt to clean this line of code up using variables, it results in the ERROR 000338.
perhaps there is some internal workings that handle the punctuation and spaces that isn't activated through arcpy calls to the tool directly
EdwardGlover1
The error was caused by the Append input being interpreted as a string as opposed to variables.  Below is syntax that worked for me.  Thanks to all for your assistance with my issue!
arcpy.Append_management('"' + FC_Unit + ';' + FC_Hrly2 + ';' + FC_Hrly + ';' + FC_Flat + ';' + FC_Matrix + '"', FC_Inven, schemaType,    fieldMappings, subtype)
