Append data not appending attributes
9858
18
03-23-2018 09:21 AM
MartinSirkovsky1
I create a script to append data from feature class in FGDB to SDE (MS Sql DBMS). I use "no_test" on append.
Script works fine, data get appended, but no attributes are transfered, just geometry. When I run the command manually, or if I set target to be another FGDB, it works.
Does anybody experienced this before?
XanderBakker
Esri Esteemed Contributor
Can you copy and paste the Python snippet of the code that works in ArcMap?
MartinSirkovsky1
I tried that. It doesn't work. And when I run the code it returns no error.
If you think about it, why would it work if the target FC is FGDB, and not work when the target FC is SDE? And why would it work if the schema type is TEST and not work when the schema type is NO TEST?
It seems to be that there is some issue with DBMS.
MartinSirkovsky1
If you wanted to see code and a subset of data I want to import, you can download it from here:
Dropbox - sample_code_and_FGDB.zip
The code is also here:
# -*- coding: utf-8 -*-
#!/usr/bin/python
Script tries to append data to Kloakk SDE (FORSYNING)
The script is testing append command, which appears not to be working
print "Starting script...."
import arcpy
inputFC = "C:/temp/kloakk.gdb/kloakk_lutir_180326"
sde = "L:/Forriting/sde connections/gisedit/KLOAK@[email protected]/"
targetFC = "kloakk_lutir_fyribils"
arcpy.env.workspace = sde
fieldMapping = 'mslink "mslink" true true false 4 Long 0 10 ,First,#,kloakk_lutir_180326,mslink,-1,-1;name "navn" true true false 150 Text 0 0 ,First,#,kloakk_lutir_180326,name,-1,-1;city "stað" true true false 50 Text 0 0 ,First,#,kloakk_lutir_180326,city,-1,-1;zip "postnr." true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,zip,-1,-1;owner "eigari" true true false 2 Text 0 0 ,First,#,kloakk_lutir_180326,owner,-1,-1;liquid "veska" true true false 2 Text 0 0 ,First,#,kloakk_lutir_180326,liquid,-1,-1;feature_type "slag" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,feature_type,-1,-1;material "tilfar" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,material,-1,-1;net_type "netverkslag" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,net_type,-1,-1;diameter "tvørmát" true true false 4 Float 3 6 ,First,#,kloakk_lutir_180326,diameter,-1,-1;elevation_cover "deksulkota" true true false 4 Float 2 6 ,First,#,kloakk_lutir_180326,elevation_cover,-1,-1;elevation_bottom "botnkota" true true false 4 Float 2 6 ,First,#,kloakk_lutir_180326,elevation_bottom,-1,-1;location "staðseting" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,location,-1,-1;comment "viðmerking" true true false 200 Text 0 0 ,First,#,kloakk_lutir_180326,comment,-1,-1;construction_year "innlagt ár" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,construction_year,-1,-1;status "støða" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,status,-1,-1;street_name "gøta" true true false 30 Text 0 0 ,First,#,kloakk_lutir_180326,street_name,-1,-1;house_nr "húsanr." true true false 10 Text 0 0 ,First,#,kloakk_lutir_180326,house_nr,-1,-1;collection_type "mátiháttur" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,collection_type,-1,-1;collection_date "skráset dagf." true true false 8 Date 0 0 ,First,#,kloakk_lutir_180326,collection_date,-1,-1;collected_by "skráset hevur" true true false 10 Text 0 0 ,First,#,kloakk_lutir_180326,collected_by,-1,-1;imported_date "innlisið frá microstation" true true false 8 Date 0 0 ,First,#,kloakk_lutir_180326,imported_date,-1,-1'
arcpy.Append_management(
inputs=inputFC,
target=targetFC,
schema_type="NO_TEST",
field_mapping = fieldMapping
# PYTHON SNIPPET EXPORTED FROM ARCMAP
# # Replace a layer/table view name with a path to a dataset (which can be a layer file) or create the layer/table view within the script
# # The following inputs are layers or table views: "FORSYNING.KLOAK.kloakk_lutir_fyribils"
# arcpy.Append_management(inputs="kloakk_lutir_180326", target="FORSYNING.KLOAK.kloakk_lutir_fyribils", schema_type="NO_TEST", field_mapping='mslink "mslink" true true false 4 Long 0 10 ,First,#,kloakk_lutir_180326,mslink,-1,-1;name "navn" true true false 150 Text 0 0 ,First,#,kloakk_lutir_180326,name,-1,-1;city "stað" true true false 50 Text 0 0 ,First,#,kloakk_lutir_180326,city,-1,-1;zip "postnr." true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,zip,-1,-1;owner "eigari" true true false 2 Text 0 0 ,First,#,kloakk_lutir_180326,owner,-1,-1;liquid "veska" true true false 2 Text 0 0 ,First,#,kloakk_lutir_180326,liquid,-1,-1;feature_type "slag" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,feature_type,-1,-1;material "tilfar" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,material,-1,-1;net_type "netverkslag" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,net_type,-1,-1;diameter "tvørmát" true true false 4 Float 3 6 ,First,#,kloakk_lutir_180326,diameter,-1,-1;elevation_cover "deksulkota" true true false 4 Float 2 6 ,First,#,kloakk_lutir_180326,elevation_cover,-1,-1;elevation_bottom "botnkota" true true false 4 Float 2 6 ,First,#,kloakk_lutir_180326,elevation_bottom,-1,-1;location "staðseting" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,location,-1,-1;comment "viðmerking" true true false 200 Text 0 0 ,First,#,kloakk_lutir_180326,comment,-1,-1;construction_year "innlagt ár" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,construction_year,-1,-1;status "støða" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,status,-1,-1;street_name "gøta" true true false 30 Text 0 0 ,First,#,kloakk_lutir_180326,street_name,-1,-1;house_nr "húsanr." true true false 10 Text 0 0 ,First,#,kloakk_lutir_180326,house_nr,-1,-1;collection_type "mátiháttur" true true false 2 Short 0 5 ,First,#,kloakk_lutir_180326,collection_type,-1,-1;collection_date "skráset dagf." true true false 8 Date 0 0 ,First,#,kloakk_lutir_180326,collection_date,-1,-1;collected_by "skráset hevur" true true false 10 Text 0 0 ,First,#,kloakk_lutir_180326,collected_by,-1,-1;imported_date "innlisið frá microstation" true true false 8 Date 0 0 ,First,#,kloakk_lutir_180326,imported_date,-1,-1', subtype="")
JoshuaBixby
MVP Esteemed Contributor
One difference I see between the ArcMap code snippet and your code is that in ArcMap you are passing a layer or table view name whereas you are passing a feature class outside of ArcMap.  Although it should not make a difference, have you tried (outside of ArcMap) making a feature layer first and then passing that to Append instead of the feature class directly?
MartinSirkovsky1
Hey Joshua.
I have tried that as well. No difference.
MartinSirkovsky1
I got it to work. It is a workaround, and I wish it wouldn't be necessary.
The attributes get appended if I defined the field mappings using a field mapping object, instead  of the field mapping definition string which can be found in python snippet.
CharlesFried
APPEND tool really sucks!
What is a "field mapping object" and how did you create that?
MartinSirkovsky1
You can read about field map object here:
FieldMappings—ArcPy classes | ArcGIS Desktop
What I have done, I have create a small function where I send the 2 paramters. The first is path to Input feature class, and second is array of arrays of [field name in input FC, corresponding field in target FC]. If the names are the same, I just pass the one item in the subarray.
The functions returns field mapping object, which I then use in append function.
Here is a sample from the code, hope it helps.
# Function which created a field mapping object
def createFieldMap(inputFC, fieldMaps):
  Creates a field map object use to define field mapping for tools which use fieldmaps
  Args:
  inputFC(string): the input feature class
  fieldMaps(array): array of input / output fields.
  First item is input field name, second is output field name.
  If output field name is not defined it is set to same as input field
  Returns:
  (object): Field mapping object which can be used to define field mappings
  # If field out is not defined set it to the same name as field in
  fms = arcpy.FieldMappings()
  print ("\nCreating field map")
  for fieldMap in fieldMaps:
  # print ("\nProcessing field {0}".format(fieldMap[0]))
  fieldIn = fieldMap[0]
  fieldOut = fieldMap[0] if len(fieldMap) == 1 else fieldMap[1]
  # print ("Field in {0}".format(fieldIn))
  # print ("Field out {0}".format(fieldOut))
  # Define field map
  fm = arcpy.FieldMap()
  fm.addInputField(inputFC, fieldIn)
  # Set ouput field properties
  fmOutputField = fm.outputField
  fmOutputField.name = fieldOut
  fm.outputField = fmOutputField
  fms.addFieldMap(fm)
  return fms
fms = createFieldMap(
  pathToinputFC,
    ['feature_id', 'id'], # values from input FC field "feature_id" will be appended to field in target FC with name "id"
    ['owner'], # the name of the field in input and target FC is save, "owner"
    ['liquid'] # the name of the field in input and target FC is save, "liquid"
# RUN Append command
  inputs=pathToinputFC,
  target=targetFC,
  field_mapping = fms
MR14
Thanks Martin! Using a field mapping object was the only working solution for appending to an sde feature class
