"Failed to open raster dataset" in zonal statistics
6855
13
07-11-2012 07:11 AM
RPatarasuk
I am trying to use zonal statistics to calculate the average amount of rainfall for each county. Here is my code:
# Import arcpy module
import arcpy
from arcpy import env
from arcpy.sa import *
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
# Input data source
arcpy.env.workspace = "S:/Work/Risa/Trials_Errors/InputFiles02"
arcpy.env.overwriteOutput = True
ZoneShapefile = "S:/Work/Risa/USA Boundary_AlbersNAD83/PINEMAP_Counties_USCensus.shp"
# Output File
OutputFolder = "S:/Work/Risa/Trials_Errors/ZonalStats"
# Loop through a list of files in the workspace
RasterFiles = arcpy.ListRasters()
# Local variables:
for filename in RasterFiles:
    print("Processing: " + filename)
    inRaster = arcpy.env.workspace + "/" + filename
    fileroot = filename
    outRaster = OutputFolder + "/" + "Avg_" + fileroot + ".tif"
    # Process: Zonal Statistics
    arcpy.gp.ZonalStatistics_sa(ZoneShapefile, "FID", inRaster, outRaster, "MEAN", "DATA")
print " "
print ":o) End Processing :)"
The problem is that when I run it, it creates this error:
Processing: ppt_1970_01.tif
File "S:/Work/Risa/Python codes/zonalStats_test.py", line 36, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\geoprocessing\_base.py", line 474, in <lambda>
return lambda *args: val(*gp_fixargs(args))
ExecuteError: ERROR 999999: Error executing function.
Failed to execute (ZonalStatistics).
What is weird is that every time when I run the program, it creates a raster file in the input folder, which I didn't specify. e.g. "t_t126". If I hit run again, will create another file and so on. These files don't give me the average value by the county either. It gave me a weird number. If the program runs properly, it should create "Avg_ppt_1970_01.tif" in the output folder.
However, if I run one file at a time (exported from Model Builder), it works fine. Here's the code that works.
import arcpy
# Local variables:
PINEMAP_Counties_USCensus = "S:/Work/Risa/USA Boundary_AlbersNAD83/PINEMAP_Counties_USCensus.shp"
ppt_1970_01_tif = "S:/Work/Risa/Trials_Errors/InputFiles02/ppt_1970_01.tif"
ZonalSt_shp2 = "S:/Work/Risa/Trials_Errors/ZonalStats/ZonalSt_shp.tif"
arcpy.gp.ZonalStatistics_sa(PINEMAP_Counties_USCensus, "FID", ppt_1970_01_tif, ZonalSt_shp2, "MEAN", "DATA")
print "Done!"
So, I don't get it why it says "Failed to open raster dataset".
Here are the sample files (see the attachments)
Any thoughts and help would be pretty much appreciated.
Thank you.
MathewCoyle
Honored Contributor
I'd imagine those rasters you are seeing are intermediate data that isn't cleaned up when it crashes since you specified your input directory as your working directory, all intermediate data will be created there. Also, I am not sure how you are accessing your ZonalStatistics tool since it isn't under the gp, it is under sa. The tool call should look like this.
arcpy.sa.ZonalStatistics(...)
Are you running this from inside an Arc session or stand alone?
RPatarasuk
Dear Matt,
Thank you for the suggestion. Let me try that. I am running it as a stand alone script. I exported the script ("arcpy.gp.ZonalStatistics_sa") from the Model Maker. So, you are saying that I should have a scratch workspace folder, right?
RPatarasuk
Dear Matt,
This what I got when I used
arcpy.sa.ZonalStatistics(ZoneShapefile, "FID", inRaster, outRaster, "MEAN", "DATA")
File "S:/Work/Risa/Python codes/zonalStats_test.py", line 38, in <module>
TypeError: ZonalStatistics() takes at most 5 arguments (6 given)
Now, i can see what you mean by those temporary raster files. That is now a minor problem. The major problem is (I think), the program can't read the raster files.
Risa
MathewCoyle
Honored Contributor
Dear Matt,
Risa
Oh right you are using the wrong syntax. ZonalStats returns a raster that you have to then save.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z000000w7000000.htm
RPatarasuk
Well, how come arcpy.gp.ZonalStatistics_sa(...) works? in a simple program like this?
import arcpy
# Local variables:
print "reading file"
arcpy.gp.ZonalStatistics_sa(PINEMAP_Counties_USCensus, "ZoneField", ppt_1970_01_tif, ZonalSt_shp2, "MEAN", "DATA")
print "Done!"
so, how come when I set a loop through the files, it doesn't work?!?!
Here is my modify code which doesn't work. I had three types of zonalstats commands and none of them works. I put "#" at the front for the time being.
import arcpy
# Input data source
arcpy.env.scratchWorkspace = "S:/Work/Risa/Trials_Errors/ScratchWorkSpace"
ZoneData = "S:/Work/Risa/USA Boundary_AlbersNAD83/PINEMAP_Counties_USCensus.shp"
# Output File
print RasterFiles
# Local variables:
    fileroot = filename
    #arcpy.gp.ZonalStatistics_sa(ZoneData, "ZoneField", inRaster, outRaster, "MEAN", "DATA")
    #arcpy.sa.ZonalStatistics(ZoneData, "ZoneField", inRaster, "MEAN", "DATA")
    #outZonalStatistics = ZonalStatistics(ZoneData, "ZoneField", inRaster, "MEAN", "DATA")
    # Process: Copy Raster
    #outZonalStatistics.save(OutputFolder + outRaster)
print " "
print arcpy.GetMessages()
MathewCoyle
Honored Contributor
Are you getting the same error?
Try this as your loop.
    print "Processing: {0}".format(filename)
    inRaster = os.path.join(input_dir,filename)
    outRaster = os.path.join(OutputFolder,"Avg_" + filename)
    saveRaster = arcpy.sa.ZonalStatistics(ZoneShapefile, "FID", inRaster, "MEAN", "DATA")
    saveRaster.save(outRaster)
RPatarasuk
Dear Matt,
Sorry, I am new to Python. I tried the loop that you gave me but it still gives me the same errors. Here is the code that I put together:
import arcpy, os
# Input data source
# Output File
print RasterFiles
print " "
# Local variables:
    input_dir = arcpy.env.workspace
    saveRaster = arcpy.sa.ZonalStatistics(ZoneData, "ZoneField", inRaster, "MEAN", "DATA")
print " "
and here is the error message:
[u'ppt_1970_03.tif', u'ppt_1970_04.tif', u'ppt_1970_05.tif']
Processing: ppt_1970_03.tif
  File "S:/Work/Risa/Python codes/zonalStats_test02.py", line 39, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 5787, in ZonalStatistics
    ignore_nodata)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Utils.py", line 47, in swapper
    result = wrapper(*args, **kwargs)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 5780, in wrapper
    ignore_nodata)
thank you very much for your help. I will post the previous code and error message shortly.
Risa
RPatarasuk
so for this code
import arcpy
# Input data source
# Output File
print RasterFiles
print " "
# Local variables:
    fileroot = filename
    outZonalStatistics = arcpy.sa.ZonalStatistics(ZoneData, "ZoneField", inRaster, "MEAN", "DATA")
    outZonalStatistics.save(outRaster)
print " "
it gives me this error, which is pretty much the same as before:
>>> ================================ RESTART ================================
  File "S:\Work\Risa\Python codes\zonalStats_test.py", line 39, in <module>
    ignore_nodata)
    ignore_nodata)
RPatarasuk
and for this
it gives me
import arcpy
# Input data source
# Output File
print RasterFiles
print " "
# Local variables:
    fileroot = filename
print " "
this error message:
