"Dataset xxx does not exist or is not supported" using Table to Domain in Python
1093
07-22-2012 11:06 PM
StephenLead
Honored Contributor
I have a directory of hundreds of *.csv files, containing code/description pairs for geodatabase domains. I'm trying to automate the creation of these domains using Python.
1) If I manually run the Table to Domain tool using a *.csv file in ArcToolbox, the domain is correctly created
2) If I create a Model using the Table to Domain tool, hard-coding in the input file (and all other parameters) then export this to a Python script, the domain is correctly created when I run the Python script
3) If I try to iterate through all *.csv files in the directory, running the Table to Domain tool for each file, I get the ""Dataset xxx does not exist or is not supported" error message:
Failed to execute. Parameters are not valid.ERROR 000732: Input Table: Dataset C:\temp\01-01.csv does not exist or is not supported
ERROR 000308: Invalid field type
Failed to execute (TableToDomain).
I suspect the problem is due to the path not being correct for the *.csv file, but I can't work out how to get it working. os.path.exists shows that the file does exist, so it may be an internal ArcGIS thing.
Note that the *.csv file does work correctly via ArcToolbox and the hard-coded Python script, so it's unlikely that the field type really is invalid.
Any help gratefully received.
Steve
AndrewChapkowski
It looks like your issue is that the csv file is open, and the arcpy function cannot work on the open/locked file.
Try this:
# Import system modules
import arcpy
from arcpy import env
import os
try:
    directory = "C:/temp/cert"
    os.chdir(directory)
    env.workspace = directory
    gdb = "template.gdb"
    extension = ".csv"
    # get a listing of all CSV files
    for myfile in os.listdir("."):
        if myfile.endswith(extension):
            #read in the domain values from the file
            f = open(myfile, 'r')
            header = f.readline().split(",")
            code = header[0]
            desc = header[1].rstrip().lstrip()
            f.close()
            del f
            #Set local parameters
            domTable = os.path.abspath(myfile)
            codeField = code
            descField = desc
            dWorkspace = gdb
            domName = myfile.split(extension)[0] #the domain takes on the name of the file, minus the ".csv" section
            domDesc = desc.replace("_"," ")
            print domTable, codeField, descField, dWorkspace, domName, domDesc
            print os.path.exists(domTable)
            arcpy.TableToDomain_management(domTable, codeField, descField, dWorkspace, domName, domDesc,"REPLACE")
            #f.close()
except Exception, e:
    # If an error occurred, print line number and error message
    import traceback, sys
    tb = sys.exc_info()[2]
    print "Line %i" % tb.tb_lineno
    print e.message
StephenLead
Honored Contributor
Bingo. Thanks for that.
Believe it or not, this answer actually popped into my head while I was brushing my teeth last night.
