AML to ArcPy
1375
01-30-2013 12:09 AM
Tom_AndersEngebakken
Hi
Is there any possibility to convert AML script to ArcPy script?
Tom Anders Engebakken
JamesCrandall
Hi
yes.  What does the AML do?
markdenil
Try looking in the Help Contents under
Geoprocessing > Creating Tools > Working with AMLs
The documents found there are:
Using AML with script tools
Python equivalents to AML functions
Python equivalents to AML directives
AML script merge two SAS cvs. files to an Arc cover file.
JamesCrandall
Aren't coverages going away soon?  You will have to be a bit more descriptive in what was actually being processed from the csv.  What type of features are you generating?  What is in the csv? etc, etc, etc...
(typically people post up specific code that they are having difficulty getting working, which as a community we can all understand and contribute ideas on how to work through problems.  Wide, open-ended "how can I" questions most often go unanswered because they require a ton of investigation to resolve.  Be very specificl, show your data, existing code, etc...)
