Alter sequence Add Location arcpy
752
01-21-2014 08:05 AM
WesleyAntal2
I want to know, if is possible create a add location in arcpy associated field "SEQUENCE" in "Stops" a one field in my feature class. Because when I used the Add Location, this not optional field sequence.
I can't used "find_best_order" in Make Route Layer.
The image show Add Location after the execute.[ATTACH=CONFIG]30664[/ATTACH]
