Aggregatin Daily Raster to Monthly
1622
05-30-2011 07:50 AM
DagnachewLegesse
Dear All,
I am trying to write a script that would automate the conversion of daily raster datasets to monthly. My script seems to work but is very slow. I know it can be improved (efficiecny and esthetics). Can it be parallelized? Can any one help? Can a for ... loop be used instead of doing same thing ten times ...
Thanks
DD
#Daily to Monthly conversion of satellite data
import sys
import datetime
import arcpy
import os
from arcpy import env
from arcpy.sa import *
arcpy.CheckOutExtension('Spatial')
print "Script is running, please wait ..."
#Set scratch workspace
arcpy.env.overwriteOutput = True
arcpy.env.scratchWorkspace = "c:\\mytempfile.gdb"
# Set environment settings
def doy2date(doy, yyyy):
        day=doy
        year=yyyy
        if isinstance(year, str):
                iyear = int(year)
        else:
                iyear = year
        if isinstance(day, str):
                iday = int(day)
        else:
                iday = day
        iday-=1
        thedate = datetime.date(iyear,1,1) + datetime.timedelta(days=iday)
        return (thedate.month)
#try:
basedir="F:\\NILE2011\\Data\\Gabriel_Nile\\resampled\\RFE\\"
#In the basedir I have 10 subdirs (2001 - 2010) inside of which I have daily values
indirs = ['rfe_2001\\','rfe_2002\\', 'rfe_2003\\', 'rfe_2004\\', 'rfe_2005\\',  \
           'rfe_2006\\', 'rfe_2007\\', 'rfe_2008\\', 'rfe_2009\\', 'rfe_2010\\']
for indir in indirs:
    env.workspace = basedir + indir
    outdir="F:\\NILE2011\\Data\\Gabriel_Nile\\resampled\\monthly\\RFE\\"
    outpath=outdir + indir
    if not os.path.isdir(outpath):
       os.mkdir(outpath)
    i=[0,0,0,0, 0, 0, 0, 0, 0, 0, 0, 0]
    rasterList = arcpy.ListRasters("*", "GRID")
    for infile in rasterList:
        yyyy = int(infile[5:9])  #e.g. of filename: rain_20021
        doy = int(infile[9:])
        mm = doy2date(doy, yyyy)
        if (mm == 1):
            if i[0] == 0:
                rsum1 = arcpy.Raster(infile)
                i[0]+=1
            else:
                rsum1 = rsum1 + infile
                i[0] += 1
        elif (mm == 2):
            if i[1] == 0:
                rsum2 = arcpy.Raster(infile)
                i[1]+=1
            else:
                rsum2 = rsum2 + infile
                i[1] += 1
        elif (mm == 3):
            if i[2] == 0:
                rsum3 = arcpy.Raster(infile)
                i[2]+=1
            else:
                rsum3 = rsum3 + infile
                i[2] += 1
        elif (mm == 4):
            if i[3] == 0:
                rsum4 = arcpy.Raster(infile)
                i[3]+=1
            else:
                rsum4 = rsum4 + infile
                i[3] += 1
        elif (mm == 5):
            if i[4] == 0:
                rsum5 = arcpy.Raster(infile)
                i[4]+=1
            else:
                rsum5 = rsum5 + infile
                i[4] += 1
        elif (mm == 6):
            if i[5] == 0:
                rsum6 = arcpy.Raster(infile)
                i[5]+=1
            else:
                rsum6 = rsum6 + infile
                i[5] += 1
        elif (mm == 7):
            if i[6] == 0:
                rsum7 = arcpy.Raster(infile)
                i[6]+=1
            else:
                rsum7 = rsum7 + infile
                i[6] += 1
        elif (mm == 8):
            if i[7] == 0:
                rsum8 = arcpy.Raster(infile)
                i[7]+=1
            else:
                rsum8 = rsum8 + infile
                i[7] += 1
        elif (mm == 9):
            if i[8] == 0:
                rsum9 = arcpy.Raster(infile)
                i[8]+=1
            else:
                rsum9 = rsum9 + infile
                i[8] += 1
        elif (mm == 10):
            if i[9] == 0:
                rsum10 = arcpy.Raster(infile)
                i[9]+=1
            else:
                rsum10 = rsum10 + infile
                i[9] += 1
        elif (mm == 11):
            if i[10] == 0:
                rsum11 = arcpy.Raster(infile)
                i[10]+=1
            else:
                rsum11 = rsum11 + infile
                i[10] += 1
        else:
            if i[11] == 0:
                rsum12 = arcpy.Raster(infile)
                i[11]+=1
            else:
                rsum12 = rsum12 + infile
                i[11] += 1
    for ii in range(0,11):
        print i[ii]
    rsum1 /=i[0]
    minfile="etmm_" + str(yyyy) + str(1)
    rsum1.save(os.path.join(outpath,minfile))
    rsum2 /=i[1]
    minfile="etmm_" + str(yyyy) + str(2)
    rsum2.save(os.path.join(outpath,minfile))
    rsum3 /=i[2]
    minfile="etmm_" + str(yyyy) + str(3)
    rsum3.save(os.path.join(outpath,minfile))
    rsum4 /=i[3]
    minfile="etmm_" + str(yyyy) + str(4)
    rsum4.save(os.path.join(outpath,minfile))
    rsum5 /=i[4]
    minfile="etmm_" + str(yyyy) + str(5)
    rsum5.save(os.path.join(outpath,minfile))
    rsum6 /=i[5]
    minfile="etmm_" + str(yyyy) + str(6)
    rsum6.save(os.path.join(outpath,minfile))
    rsum7 /=i[6]
    minfile="etmm_" + str(yyyy) + str(7)
    rsum7.save(os.path.join(outpath,minfile))
    rsum8 /=i[7]
    minfile="etmm_" + str(yyyy) + str(8)
    rsum8.save(os.path.join(outpath,minfile))
    rsum9 /=i[8]
    minfile="etmm_" + str(yyyy) + str(9)
    rsum9.save(os.path.join(outpath,minfile))
    rsum10 /=i[9]
    minfile="etmm_" + str(yyyy) + str(10)
    rsum10.save(os.path.join(outpath,minfile))
    rsum11 /=i[10]
    minfile="etmm_" + str(yyyy) + str(11)
    rsum11.save(os.path.join(outpath,minfile))
    rsum12 /=i[11]
    minfile="etmm_" + str(yyyy) + str(12)
    rsum12.save(os.path.join(outpath,minfile))
    print "In the name of the ..... " + str(yyyy)
#except:
#    print arcpy.GetMessages(2)
DagnachewLegesse
Given some more time and thinking, I amended my own code as follows: it seems to work but Once it finishes a subdirectory containing list of rasters, it 'walks' further into the GRID subfolder itself thus giving error. Is there any way that we can prevent it from looking into the GRID folder itself?
try:
    basedir="C:\\N2011\\Data\\NILE\\"
    subdir = "resampled\\"
    datadir=basedir + subdir
    for dirs, subdirs, files in os.walk(datadir):
        env.workspace = os.path.join(dirs)
        outtemp = env.workspace
#        print rasterList
        if len(rasterList) > 0:
#            print outtemp
            outpath = outtemp.replace ('resampled', 'monthly')
            for i in range(1,13):
                counter = 0
                        os.makedirs(outpath)
                        print outpath
                    yyyy = int(infile[2:4])
                    mm = int(infile[4:6])
                    if (mm == i):
                        if counter == 0:
                            counter+=1
                        else:
                            counter += 1
                            print infile
                yyyy += 2000
                moutfile="mmpet_" + str(yyyy) + str(i)
                rsum1.save(os.path.join(outpath,moutfile))
                print " ===> " + moutfile
except Exception as e:
    print e.message
DagnachewLegesse
Still trying tom improve it. I really need suggestions though.
#Aggregating daily climate GRIDS to monthly
#DD June 2011
import sys
import datetime
import arcpy
import os
    day=doy
    year=yyyy
            iyear = int(year)
    else:
            iyear = year
            iday = int(day)
    else:
            iday = day
    iday-=1
try:
    basedir="C:\\N2011\\Data\\"
#        print rasterList
        if len(rasterList) > 1:     #if subdirectory contains only one GRID file --> don't walk in
            print outtemp
                counter = 0
                #Create expression for Cell Statistics
                rstListExp = []
                        print outpath
                    try:
                        yyyy = int(infile[2:4]) + 2000  #if filename et010101
                    except ValueError:
                        yyyy = int(infile[5:9])           #if filename == rain_2001100
                    if (mm == i):
                        rstListExp.append(infile)
 #               print rstListExp
                rsum1 = CellStatistics(rstListExp, "SUM", "DATA")
                moutfile="mm_" + infile[:2] + str(yyyy) + str(i).zfill(2)
    print e.message
    sys.exit(1)
finally:
     print 'Goodbye, world!'
DagnachewLegesse
[PHP]#Aggregating daily climate GRIDS to monthly
#DD June 2011
import sys
import datetime
import arcpy
import os
    day=doy
    year=yyyy
            iyear = int(year)
    else:
            iyear = year
            iday = int(day)
    else:
            iday = day
    iday-=1
try:
#        print rasterList
            print outtemp
                counter = 0
                rstListExp = []
                        print outpath
                    try:
                    except ValueError:
                    if (mm == i):
#               print rstListExp
    print e.message
    sys.exit(1)
finally:
     print 'Goodbye, world!'[/PHP]
