After 10.2.1 update Arcpy 64 bit ERROR
3250
04-14-2014 08:04 AM
JA4
I've updated my ArcGIS desktop version from 10.2 to 10.2.1 and have noticed that when I run the 64 bit version of IDLE I now get an error when trying to import arcpy:
Python 2.7.3 (default, Apr 10 2012, 23:24:47) [MSC v.1500 64 bit (AMD64)] on win32
Type "copyright", "credits" or "license()" for more information.
>>> import arcpy
  File "<pyshell#0>", line 1, in <module>
    import arcpy
  File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\__init__.py", line 24, in <module>
    from arcpy.toolbox import *
  File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\toolbox.py", line 656, in <module>
    from na import AddFieldToAnalysisLayer as AddFieldToAnalysisLayer_na
  File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\na.py", line 26, in <module>
    import _na
  File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\_na.py", line 46, in <module>
    class StreetDirectionsProperties(na.StreetDirectionsProperties):
AttributeError: 'module' object has no attribute 'StreetDirectionsProperties'
So the error seems to come from failing to find a module for the Network Analyst extension, which I see is listed as one of the updated Python features in 10.2.1: (http://resources.arcgis.com/en/help/main/10.2/#/What_s_new_in_ArcGIS_10_2_1/016w0000005v000000/). I'm guessing the 10.2.1 release didn't update both the 32 AND 64 bit versions of Arcpy when installing Python 2.7.5. The version I still have in C:\Python27\ArcGISx6410.2 is 2.7.3, but this seems to now be in conflict with the new install.
Can someone please help me figure out how to correct this issue with IDLE? I really need to be able to run stand-alone 64 bit Arcpy scripts. I'm aware of 64 bit background geoprocessing in ArcMap/ArcCatalog, but this is different. I run heavy lifting stand-alone scripts that must be in the 64 bit version.
Thank you
MathewCoyle
Honored Contributor
You are correct you need Python 2.7.5 with ArcGIS 10.2.1. Have you tried installing the 64-bit upgrade for 10.2.1?
JA4
Do you mean the ESRI specific Python library or Python 2.7.5 from the Python.org website? I have tried installing 2.7.5 64 bit version from Python.org and that didn't fix it.
Is there a downloadable update to the 64 bit background geoprocessing package for 10.2.1 available from ESRI?
MathewCoyle
Honored Contributor
You need to installed the 64-bit GP upgrade from Esri. From the sounds of what you've done on your environment I would uninstall everything and start from scratch.
