Adding several .lyr into different MXD stored in one folder with several sub-folder
2057
5
07-19-2022 12:05 AM
Paul-EmmanuelLeroux
Hello community,
I am trying to add the 3 same .lyr layers into different mxd in a folder with serveral sub-folders and many sub-sub folders.
I was helped to draw a script. However, I failed to run it. I would really apprciate if the community could help me to correct the script PLEASE!
I have another question where is this specific script supposed to be run, in Python for Arcmap or Python console on Windows?
import arcpy
import arcpy.mapping as m
import os
root_folder = r"path\to\root\folder"
add_lyr_1 = r"path\to\file1.lyr"
add_lyr_2 = r"path\to\file2.lyr"
add_lyr_3 = r"path\to\file3.lyr"
## create list of lyr files
add_lyrs = [add_lyr_1, add_lyr_2, add_lyr_3]
mxd_paths = []
## add all mxd paths to a list
for root, dirs, files in os.walk (root_folder):
    for f in files:
        if f.endswith(".mxd"):
            mxd_paths.append("{0}\\{1}".format(root, f))
## print to test
#print(mxd_paths)
for mxd_doc in mxd_paths:
    mxd_name = mxd_doc.rsplit("\\")[-1]
    arcpy.AddMessage(mxd_name)
    ## access the mxd
    mxd = m.MapDocument(mxd_doc)
    ## only access the desired dataframe
    ## you might want to use a dataframe name / wildcard to
    ## add layers to correct dataframe if you have multiple
    df = m.ListDataFrames(mxd)[0]
    ## add each layer file, one on top of the other.
    for lyr_file in add_lyrs:
        add_lyr = m.Layer(lyr_file)
        m.AddLayer(df, add_lyr ,"TOP")
    mxd.save()
Paulo
Clubdebambos
MVP Regular Contributor
Hi @Paul-EmmanuelLeroux
I originally wrote this in StackExchange 🙂
How have you tried to run it so far? What errors are you getting? Details and screenshots will help.
As a personal preference I use PyScripter to run Python Scripts outside of the ArcMap/Pro environment.
You can also use IDLE that is installed with Python, or you can create/load a script within the ArcMap/Pro software.
~ learn.finaldraftmapping.com
Paul-EmmanuelLeroux
In IDLE the error appear after the last part:
File "<pyshell#11>", line 2, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.8\ArcPy\arcpy\arcobjects\mixins.py", line 429, in __init__
super(LayerMixin, self).__init__(lyrfile)
File "C:\Program Files (x86)\ArcGIS\Desktop10.8\ArcPy\arcpy\arcobjects\_base.py", line 47, in __init__
for arg in args))
ValueError: Objet\xa0: source of data not valid in the layer CreateObject
Clubdebambos
Can you show the full code you are running? It could be a path error to the lyr files you are attempting to use.
What have you added for the paths here?
Paul-EmmanuelLeroux
Sorted
Paul-EmmanuelLeroux
I corrected something in the first loop:
for root, dirs, files in os.walk(root_folder):
for f in files:
if f[-4:]==(".mxd"):
in the second loop I have a problem with mxd = m.MapDocument(mxd_doc)
