Add result of MakeTableView to MXD
1085
09-19-2012 01:11 PM
RobertMartin2
I have a script which uses MakeTableView. The problem is that when I run this script as a tool, the output does not get added to the MXD. I had this problem previously with a feature layer, but was able to add the layer manually with AddLayer. The problem is that I can't use AddLayer with a table view. Does anyone know if there's an equivalent command for adding a table view to the TOC?
Thanks!
AndrewChapkowski
