Add permissions but no DELETE
1216
05-29-2025 09:40 AM
kapalczynski
I know that I can add permissions as seen below... But this gives all EDIT permissions...
I want ADD and UPDATE but NO DELETE...
Can this be done?
# Import system modules
import arcpy
# Set local variables
datasetName = "c:/Connections/[email protected]/production.GDB.ctgFuseFeature"
# Run ChangePrivileges
arcpy.management.ChangePrivileges(datasetName, "WENDELCLARK", "GRANT", "GRANT")
DanPatterson
MVP Esteemed Contributor
According to the help
Change Privileges (Data Management)—ArcGIS Pro | Documentation
The RDBMS equivalent commands for the Edit parameter are Update, Insert, and Delete. All three are granted or revoked simultaneously by the Edit parameter
fine-tuning doesn't appear to be accessable throught this approach
... sort of retired...
kapalczynski
Dang that's unfortunate
DavidPike
MVP Notable Contributor
What about via the DBMS?
AlfredBaldenweck
MVP Frequent Contributor
The trick is to not use arcpy, like @DavidPike suggested. I think this worked for me in the past; give it a shot?
stateGrpDict = {
            "ak": r"[usergroup]",
            "az": r"[usergroup]",
# Create Table View to grab connection information.
# This part makes more sense in context, but
# basically i'm grabbing the name of a US State
#from the database's name via the connection.
db = arcpy.management.MakeTableView(inTbl)[0]
con = db.connectionProperties
conDB = con["connection_info"]["database"]
conDBS = conDB[4:6]
conDS = con["dataset"]
grp = stateGrpDict.get(conDBS, None)
# Apply View, Insert, and Update privileges, but not Delete
# privileges.
# ChangePrivileges() is all or nothing.
# This way, no one can delete the records.
executor = arcpy.ArcSDESQLExecute(IN_WKSPC)
sql = f"GRANT SELECT, INSERT, UPDATE ON {conDS} TO {grp}"
executor.execute(sql)
del executor
