Add layer from one datar frame to others in same .mxd
2603
05-06-2014 07:05 PM
RossRomero
I need to write a script that adds the parks layer from the parks data frame in the Austin_TX.mxd (attached)to the other two data frames in the same map document.
Any help would be greatly appreciated. I know this is a very easy script, but I cant seem to wrap my mind around doing it.
Zeke
Honored Contributor
You want to use InsertLayer. Give that a try and post back with any problems you have.
RossRomero
This is what I've come up with so far. I don't know how to add that layer to the other two data frames in the Austin_TX.mxd file.
import arcpy
mxd = arcpy.mapping.MapDocument(r"P:\G4910\G4910_06\Data\Data\Exercise10\Austin_TX.mxd")
df = arcpy.mapping.ListDataFrames(mxd, "Parks")[0]
addLayer = arcpy.mapping.Layer(r"parks.lyr")
arcpy.mapping.AddLayer(df, addLayer, "BOTTOM")
mxd.saveACopy(r"P:\G4910\G4910_06\Data\Data\Exercise10\Austin_TX.mxd")
del mxd, addLayer
Zeke
Honored Contributor
Well, that's not using InsertLayer. There's a good example at the link I provided. Anyway, if you want to use AddLayer. change this:
to this:
df = arcpy.mapping.ListDataFrames(mxd, "Parks")[1]
and so on. the [0] refers to your first data frame. [1] is the second, [2] is the third, etc.
You can call the function twice, or put it in a loop something like:
import arcpy
mxd = arcpy.mapping.MapDocument(r"P:\G4910\G4910_06\Data\Data\Exercise10\Austin_TX.mxd") dfList = arcpy.mapping.ListDataFrames(mxd, "Parks") addLayer = arcpy.mapping.Layer("parks.lyr")
for df in dfList:
mxd.saveACopy(r"P:\G4910\G4910_06\Data\Data\Exercise10\Austin_TX.mxd") del mxd, addLayer
