Add item 'NoneType' object is not subscriptable
1810
07-04-2024 02:29 AM
Iron_Mark
I am trying to automate stuff with python (I am using Jupyter through anaconda) and it's the first time using add an item with Arcgis api for python and I get this error when trying to add a Shapefile into my Enterprise portal.
Is this related to the connection to the portal or to the add item?
The string for the connection doesn't give me any error, but the add function does.
Code is:
from arcgis.gis import GIS
gis = GIS(url="https://something.cloud.esriuk.com/portal",
username="company\\emailaddressusedformyuser",
password="mypassword")
ip = {
"type" : "Shapefile",
"title" : "TEST",
"tags" : "test"
item = gis.content.add(data=r"data\TEST.zip", item_properties=ip)
item
Any suggestions would be higlhy appreciated, thanks.
DanPatterson
MVP Esteemed Contributor
Try printing gis.content first to see if there is any content, then check to see if data exists and ...
Test for None using the principles here
Solved: TypeError: 'NoneType' object is not iterable - Esri Community
... sort of retired...
Iron_Mark
Hi Dan,
Thank you for your reply.
What I get is an empty list [ ]  when I query for my user contents.
Any thoughts? I am using jupyter notebooks through Anaconda and we have an Enterprise authentication system.
Thanks
DanPatterson
Sorry, I work on a local install.
dgiersz_cuyahoga
Try putting the full filepath to the ZIP file.
#CLE #sloth
