Add field alias if field already exists
1610
06-02-2011 12:29 PM
AnthonyFarndon
Is it possible to add/amend  field alias if field already exists i.e. not going the AddField_management() route?
MathewCoyle
Honored Contributor
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v0000001p000000.htm
has some good info on field properties
This should get you started
fields = arcpy.ListFields("layer")
for f in fields:
    if f.name == "Something you want to change"
        f.aliasName = "New Alias"
AnthonyFarndon
Thanks, hadn't realised the listFields 'getter' could also be used as a setter!
MathewCoyle
Honored Contributor
Oh I think you might be right, I may have used field mappings before to set them.
AnthonyFarndon
OK, thanks 😞
