Add basemap by arcpy (python)
6004
04-14-2014 02:12 PM
TakeoShibata
Hi All
I am wondering how to add Base Map by arcpy.
It is such a simple operation if you use ArcGIS Desktop GUI
But I am wondering how to do the same in arcpy code.
[ATTACH=CONFIG]33091[/ATTACH]
MattEiben
If you add one of those basemaps to your ArcMap session, you can right click on the "Basemap" group layer on your Table of Contents and save a .lyr file to your system somewhere.  (Use the "Save As Layer File..." button) Then you could run something like this in your script to add it to your map.
basemapLayer = arcpy.mapping.Layer(path_to_your_basemap_lyr_file)
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd, "*")[0]
arcpy.mapping.AddLayer(df, basemapLayer, "BOTTOM")
Of course, the downside to this method is you'd need a copy of the .lyr file for that basemap somewhere on your system.
Matt
PedroHenrique_de_Aquino_Bravin
Hi Matt,
Thank you for put this process in a script form, it is very useful!
Best regards,
Pedro Bravini
