add and calculate field
1539
09-29-2011 03:40 PM
YinghaiKe
I want to add a field "filename" with "TEXT" format for a shape file and assign this field with the file name. The shape file only has one record. Here is my code:
import arcpy
from arcpy import env
# Set environment settings
env.workspace = "D:/Workspace"
fc = "01055p.shp"
tmp = fcname.split('.')
tmp2 = tmp[0]
arcpy.AddField_management(fc, "filename", "TEXT", "", "", 25)
arcpy.CalculateField_management(fc, "filename", tmp2)
But I got error saying "CalculateField_management" failed to execute. Is there any problem with the script? Thanks!
MarcNakleh
Hello,
If you're creating the textfield filename, and trying to write text to it, I think I see the problem.
For string literals, your expression value needs to be encapsulated by quotes when it's passed to the Field Calculator. Your code should therefore be:
arcpy.CalculateField_management(fc, "filename", '"' + tmp2 + '"')
What you were passing to the expression field before was this:
myfilename
whereas what you wanted to send, and what you'd see in the Field Calculator, is this:
"myfilename"
Hope this helps!
StacyRendall1
What is fcname? You don't specify it before calling it. Although, that isn't directly related to your error.
You could try adding:
arcpy.AddMessage('%s' % tmp2)
just before your add field line, to check what tmp2 is actually coming out like before the calculation.
MarcNakleh
Hello,
myfilename
"myfilename"
Hope this helps!
YinghaiKe
Thank you, mnakleh, that works great! Thanks!
