add a list in arcpy.MakeFeatureLayer_management
4793
13
09-19-2022 05:53 AM
danielROUFFART1
Hi! i ty to make
output = r'C:\Temp\test.gdb\BAV1'
target = r'C:\download
fcs2 = [a, b, c, d]
# Set the workspace
arcpy.env.workspace = ready
for x in range(len(fcs2)):
    arcpy.MakeFeatureLayer_management(fcs2, output)
arcpy.SelectLayerByAttribute_management(output, 'NEW_SELECTION', "city = 'Paris'")
arcpy.CopyFeatures_management(output, target)
but i've got an error message, can you help me about my script for put my list please
Tags (1)
by Anonymous User
Not applicable
You could try using the addfielddeliminators to ensure that the SQL is formatted correctly and check for the field 'commune' in each fetureclass.
for fc in fcs2:
    flds = [f.name for f in arcpy.ListFields(fc)]
    if 'commune' in flds:
        # build the query using field deliminators
        whereclause = f"""{arcpy.AddFieldDelimiters(fc, 'commune')} = 'Perpignan'"""
        arcpy.MakeFeatureLayer_management(fc, fc + '_lyr', whereclause)
        # continue with copying
    else:
        print (f'commune not found in {fc}')
danielROUFFART1
ok so if i don't have a correspondence with commune field i've got an error message so i need to change my script with that no?
for i in fcs:
    arcpy.MakeFeatureLayer_management(i, i + "_lyr")
    print('lyr')
    # fichier temporaire d'affinage de la selection
    for fc in fcs2:
        if 'nomcom' in flds:
            whereclause = f"""{arcpy.AddFieldDelimiters(fc, 'nomcom')} = 'SALEILLES'"""
        else:
            print(f'commune not found in {fc}')
    if fc is not None:
        arcpy.SelectLayerByAttribute_management(i + "_lyr", 'NEW_SELECTION', fc)
        fc_desc = arcpy.Describe(i)
        print("fc_desc")
        print (fc_desc)
        out_name = fc_desc.baseName + '_export'
        print (out_name)
        new_name = i.replace('.','_')
        print(new_name)
        new_name2 = new_name.replace('rezo_h','')
        print(new_name2)
        ditched_features_path = os.path.join(out_name, sauve + "\_"+ new_name2)
        print (ditched_features_path)
        # copie de la selection en shape
        arcpy.CopyFeatures_management(i + "_lyr", ditched_features_path)
    else:
        print ("no data")
but have got always this error message
arcgisscripting.ExecuteError: ERROR 000358: Invalid expression
by Anonymous User
Not applicable
If your fields change between featureclasses, and the sql needs to change between each featureclass, you can use if/elif to create your sql.
arcpy.env.overwriteOutput = True #<- move to top of script since it only needs to be set once
for fc in fcs2:
    # create empty whereclause variable
    whereclause = None
    elif 'nomcom' in flds:
    else:
    if whereclause:
        # describe first to get the name
        fc_desc = arcpy.Describe(fc)
        print("fc_desc")
        print (fc_desc)
        # create the temp layer with selection
        tmpLyr = arcpy.MakeFeatureLayer_management(fc, fc_desc.name + '_lyr', whereclause)
        print (out_name)
        new_name = fc_desc.name.replace('.','_').replace('rezo_h','')
        print(new_name)
        ditched_features_path = os.path.join(out_name, sauve + "\_"+ new_name)
        arcpy.CopyFeatures_management(tmpLyr, ditched_features_path)
    else:
        print ("no data")
danielROUFFART1
thanks for your help!
