Accuracy loss when creating polygons with Polygon()
2306
10-08-2014 05:41 AM
ChrisHills
When creating polygons with Polygon() the results are not accurate as expected. Take the following script:-
import arcpy
startx = 285000
starty = 138000
boxsize = 1536
boxcount = 2
features = []
for colx in range(1,boxcount+1):
  for coly in range(1,boxcount+1):
    top    = (starty+(boxsize*coly))
    bottom = (starty+(boxsize*(coly-1)))
    left   = (startx+(boxsize*(colx-1)))
    right  = (startx+(boxsize*colx))
    feature_info = [[[left, bottom],
                     [right, bottom],
                     [right, top],
                     [left, top]]]
    for feature in feature_info:
      features.append(arcpy.Polygon(arcpy.Array([arcpy.Point(*coords) for coords in feature])))
      print left, bottom, right, top
for feature in features:
  print feature.extent
This produces the following output:-
285000 138000 286536 139536
285000 139536 286536 141072
286536 138000 288072 139536
286536 139536 288072 141072
285000.00012207 138000.00012207 286536.00012207 139536.00012207 NaN NaN NaN NaN
285000.00012207 139536.00012207 286536.00012207 141072.00012207 NaN NaN NaN NaN
286536.00012207 138000.00012207 288072.00012207 139536.00012207 NaN NaN NaN NaN
286536.00012207 139536.00012207 288072.00012207 141072.00012207 NaN NaN NaN NaN
As you can see, instead of the resulting boundary being equal to the input points, it has changed them by 0.00012207. This is unexpected and unwanted. How do I create my polygons without this error?
DanPatterson_Retired
That is an old issue... have a read  Create a spatial reference (aka projection) for the data.  any UTM zone will work
ChrisHills
I updated my script to include a spatial reference and it now gives the expected result:-
import arcpy
startx = 285000
starty = 138000
boxsize = 1536
boxcount = 2
features = []
# British National Grid
srid = arcpy.SpatialReference(27700)
                     [right, bottom],
                     [right, top],
                     [left, top]]]
      features.append(arcpy.Polygon(arcpy.Array([arcpy.Point(*coords) for coords in feature]),srid))
285000 138000 286536 139536 NaN NaN NaN NaN
285000 139536 286536 141072 NaN NaN NaN NaN
286536 138000 288072 139536 NaN NaN NaN NaN
286536 139536 288072 141072 NaN NaN NaN NaN
ChrisHills
Thank you Dan for your helpful answer.
