Dear Readers,
good afternoon.
I am using ArcPy 3.6.10 from ArcGIS Pro. We are creating an intersection of a national layer from a SDE 'e:\\Idea\\Connections\\xxmartspatial.sde\\xxmartspatial.BASE.MY_LAND_UNIT' against a state feature 'e:\\IDEAData\\Extracts\\Work\\IDEAMapIT_10.gdb\\_DE_' (currently DE) in a file geodatabase and writing the result to the same file geodatabase: 'e:\\IDEAData\\Extracts\\Work\\IDEAMapIT_10.gdb\\MY_LAND_UNIT'
ExecuteError('Failed to execute. Parameters are not valid.\n
ERROR 000732: Input Features:
Dataset e:\\Idea\\Connections\\xxmartspatial.sde\\xxmartspatial.BASE.MY_LAND_UNIT does not exist or is not supported\nFailed to execute (Clip).\n',)
The connection to SDE for reading national layer is a superior user than the app user - once i get this code to work, I will degrade the SDE connection user.
i verified the spelling cases for sde connection and all we are doing is a read- but the user has superior permissions on the SDE.
arcpy.Clip_analysis(InputPLUFCFullName, TempStateFCFullName, OutputPLUFCFullName, "0.01 Meters")
'e:\\Idea\\Connections\\xxmartspatial.sde\\xxmartspatial.BASE.MY_LAND_UNIT' - #SDE input PLU FC FullName
'e:\\IDEAData\\Extracts\\Work\\IDEAMapIT_10.gdb\\_DE_' #Temp State
'0.01 Meters'
Any direction would be of great help.
thanks and regards
ravi kaushika.
