Add support for pathlib.Path objects to arcpy
13963
31
04-09-2020 09:20 AM
Status: Implemented
ScottDavis
pathlib seems to be the preferred method for working with system paths in Python 3. We've started using it in place of `os.path` in our office recently and really like it. However, we've run into problems with using it with arcpy. For example:
workspace = pathlib.Path('C:\some path') \ 'anotherfolder' \ 'connection.sde'
with arcpy.EnvManager(workspace=workspace):
    pass‍‍‍‍‍‍
Throws this error: "RuntimeError: Object: Error in accessing environment <workspace>"
To work around this, we end up wrapping all of our Path object with str(). For example:
workspace = str(pathlib.Path('C:\some path') \ 'anotherfolder' \ 'connection.sde')
    pass‍‍‍‍‍‍‍‍‍
It would be great if arcpy (Pro version) handled these Path objects natively!
31 Comments
KoryKramer
👍Thanks, Shaun!
BlakeTerhune
Thank you for the consideration @ShaunWalbridge😊
EthanSchaefer
It seems to me that one (partial?) solution would be to wrap each function/method so that any passed object with a __fspath__ method is converted to the result of calling that method. This is essentially the same logic behind os.fspath(), which returns arbitrary strings unchanged, even if they couldn't possibly represent a path. Of course, it sequences of paths must also be covered, that could be accommodated, too. But if there are more complicated scenarios that I haven't anticipated, they may be harder to support.
Incidentally, the basic approach I outlined is how I deal with this problem (at an abstract level) when generating scripts on the fly and passing them via propy.bat.
philnagel
Is there any progress on this? It's quite annoying to be stuck with legacy path handling from Python 2, or always having to manually convert paths to strings, just because arcpy still does not support pathlib almost 3 years after this idea was posted.
OliviaHughes
I'd really like to upvote this as well. I want to use pathlib Path objects in my scripts as we use that as standard procedure for other file handling scripts. Having to break this pattern due to the arcpy library is really inconvenient.
subora_iastate
I agree with Olivia, any progress incorporating pathlib would be greatly appreciated. Maybe I am mistaken, but I think just being able to pass pathlib.Path types into parameter fields would be sufficient.
MErikReedAugusta
I get that pathlib outputs might be a naturally-expected addition to this, but given the apparent devtime required, perhaps it might be best to release this in stages?  Surely pathlib inputs could be achieved for all or most of arcpy in a minor version or two, rather than this three-year-and-counting wait?
Especially when one considers the lag time for many organizations between release and deployment of new versions, I shudder to think of this still being unavailable to me a decade from now.
JordanCarmona
Pathlib inputs would be a great MVP for this.
MortenBackNielsen
Does anybody know the status for this - it's a bit frustrating thay you always have to convert a Path to a dump string before parsing it to ArcPy? 🙂
HannesZiegler
We're working on this!  This status does not guarantee that the functionality will be in the next release, but development work has begun. Release cycles vary by product so make sure to check the product life cycle information to get an idea of when to expect the next release.
