Ability to Turn Off Fields on an existing Layer with Python in ArcGISPro
1915
03-28-2021 07:11 PM
Status: Already Offered
LeandraGordon
This is related to the post: https://community.esri.com/t5/python-questions/turn-off-fields-with-python/td-p/403316/page/2
by @DylanHarwell
There is a need to be able to turn on and off Fields in Python on Layers that have been created by joins or on existing layers in a project via ArcPy.
This is a sample workflow:
1. Create a new feature class via Spatial Join of 2 Layers
2. Use Create Feature Layer to create a layer from the Feature Class
3. Create a creates a geoprocessing field info object from the new Layer.
4. Iterate through the field info object to set fields as hidden or visible
5. NEW: Use the Field Info object to set the fields in the new Layer created earlier.
OR make the arcpy.Describe().FieldInfo function able to access a new Feature Class that not currently displayed as a Layer.There were (cumbersome) solutions for ArcMap.
3 Comments
JeffBarrette
Leandra,
This can be done using Python CIM Access.  Here is the help topic that describes what that means and there is even a sample that does exactly what you are requesting.
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/python-cim-access.htm
Code snippet under Example 2: Modify field properties
# Reference a project, map, and layer using arcpy.mp
p = arcpy.mp.ArcGISProject('current')
m = p.listMaps('Map')[0]
lyr = m.listLayers('GreatLakes')[0]
# Get the layer's CIM definition
cim_lyr = lyr.getDefinition('V2')
# Make changes to field properties
for fd in cim_lyr.featureTable.fieldDescriptions:
    if fd.fieldName == "OBJECTID":
        fd.visible = False            #Do not display this field
    if fd.fieldName == "Shape_Area":
        fd.alias = "Area (hectares)"  #Change field alias
# Push the changes back to the layer object
lyr.setDefinition(cim_lyr)
I hope this helps.
Jeff - Layout and arcpy.mp teams
KoryKramer
LeandraGordon
Thanks Again!
