What is standard and not ... in python
2564
01-16-2016 10:16 AM
DanPatterson_Retired
0 0 2,564
Some more information on finding python, its modules and whether they are built-in, modules of the standard distribution or those in the site-packages folder
References:
  29.12. inspect — Inspect live objects — Python 3.4.4 documentation look at the table on Types and Members
  http://stackoverflow.com/questions/247770/retrieving-python-module-path just one of hundreds of examples.
TypeAttributeDescription
module__doc__documentation string
__file__filename (missing for built-in modules)
TipsExample
A standard installation compatible with ArcMap and arcpy is assumed.
These:
  • dir(module_name)
  • help(module_name)
are your friends.
Look for a __file__ property in the function/property list.
The os module does...
>>> import  os
>>> dir(os)
[ ... snip ... '__doc__', '__file__',
 '__loader__', '__name__', ... snip ... ]
>>> os.__file__
'C:\\Python34\\lib\\os.py'
The time module doesn't
>>> import time
>>> dir(time)
>>> time.__file__   # I will try anyway
  File "<interactive input>", line 1, in <module>
AttributeError: 'module' object has no attribute '__file__'
Modules in the
C:\PythonXX\lib\
folder will have a __file__ property.
>>> # from ... C:\Python34\Lib   ... folder
>>> import collections
>>> collections.__file__
'C:\\Python34\\lib\\collections\\__init__.py'
Modules that aren't part of the standard distribution and have to be installed via pip or other means, get put in the site-packages folder and they will have a __file__
How about arcpy?
>>> import arcpy
>>> arcpy.__file__
'C:\\Program Files\\ArcGIS\\Pro\\Resources\\ArcPy\\arcpy\\__init__.py'
And my fav...
>>> import numpy as np
>>> np.__file__
'C:\\Python34\\lib\\site-packages\\numpy\\__init__.py'
You can use the inspect module as well... all the cool programmers do ...
Numpy was previously imported as np.
Notice the results are the same as the np.__file__ approach.
>>> import inspect
>>> inspect.getfile(np)
Lets try time.
>>> inspect.getfile(time)
  File "C:\Python34\lib\inspect.py", line 518, in getfile
    raise TypeError('{!r} is a built-in module'.format(object))
TypeError: <module 'time' (built-in)> is a built-in module
No... it is a built-in.
But... you can another way...
>>> import time
>>> inspect.getmodule(time)
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
