Usually when updating a URL on portal I use ArcGIS Online Assistant, it is a excellent resource for quick maintenance, but in this case I had to update hundreds of Web Maps and using AGO Assistant would have been time consuming.
I initially started by looking at the ArcGIS API for python version 1.6.2, but unfortunately I had no luck in updating the services with the API, so searching the web for a scrip to update web map services I found this one Example: Update the URL of a service in a web map—Portal for ArcGIS (10.7 and 10.7.1) | ArcGIS Enter... but the script is still in python 2.7 and its end is near Python 2.7 Countdown.
So I took the time to update the script using the standard library as far as possible but I do like requests · PyPI to handle my web calls.
Well here is the result I hope someone finds it helpful ![]()
This Crawls trough all your portals content and updates the DNS
It goes without saying use with caution and at own risk.
# Original Source: Example: Update the URL of a service in a web map—Portal for ArcGIS (10.7 and 10.7.1) | ArcGIS Enter... import urllib.request import json import requests from urllib.parse import urlencode import logging import os def header(): return { 'content-type': "application/x-www-form-urlencoded" , 'accept': "application/json" , 'cache-control': "no-cache" } def get_token(portal_admin_url, portal_username, portal_password, root_url): # Generate Token url = f"{portal_admin_url}/sharing/rest/generateToken" payload = { 'f': 'json' , 'username': portal_username , 'password': portal_password , 'client': 'referer' , 'referer': f'{root_url}' , 'expiration': '100' } return json.loads( requests.request( "POST" , url , data=payload , headers=header() , verify=False ).text )['token'] def search_portal(portal_url, query=None, totalResults=None, sortField='numviews', sortOrder='desc', token=None): all_results = [] if not totalResults or totalResults > 100: num_results = 100 else: num_results = totalResults results = __search__( portal_url , query , num_results , sortField , sortOrder , 0 , token ) if not 'error' in results.keys(): if not totalResults: totalResults = results['total'] # Return all of the results. all_results.extend(results['results']) while (results['nextStart'] > 0 and results['nextStart'] < totalResults): # Do some math to ensure it only # returns the total results requested. num_results = min(totalResults - results['nextStart'] + 1, 100) results = __search__( portalUrl=portal_url , query=query , sortField=sortField , sortOrder=sortOrder , token=token , start=results['nextStart'] ) all_results.extend(results['results']) return all_results else: logging.info(results['error']['message']) return results def __search__(portalUrl, query=None, numResults=1000, sortField='numviews', sortOrder='desc', start=0, token=None): '''Retrieve a single page of search results.''' params = { 'q': query , 'num': numResults , 'sortField': sortField , 'sortOrder': sortOrder , 'f': 'json' , 'start': start } if token: # Adding a token provides an authenticated search. params['token'] = token return json.loads( requests.request( "POST" , f'{portalUrl}/sharing/rest/search?' , data=params , headers=header() , verify=False ).text ) def webmap_get_data_or_info(webmapId, portalUrl, token, data_or_info): # Query either the rest info or the rest data try: params = { 'token': token , 'f': 'json' } logging.info(f'Getting Info for: {webmapId}') item_data_req = requests.request( "POST" , f'{portalUrl}/sharing/content/items/{webmapId}{data_or_info}?' , data=params , headers=header() , verify=False ).text logging.info(item_data_req) return json.loads(item_data_req) except Exception as e: logging.error(str(e)) def update_webmap_with_folder(webmapId, portalUrl, token, new_data, owner, folder=None): # Update dns in webmap located in root or a folder params = {'token': token} data = {'text': str(new_data)} folder = "" if folder is None else f"/{folder}/" mod_request = f"{portalUrl}/sharing/rest/content/users/{owner}{folder}items/{webmapId}/update?" \ f"{urllib.parse.urlencode(params)}" logging.info(mod_request) # set verify to False if certificates are not valid. try: logging.info( requests.request( "POST" , mod_request , data=data , headers=header() , verify=True ).text ) except Exception as e: logging.error(e) def update_webmap_service(webmapId, old_dns, new_dns, token, portalUrl): '''Replaces the URL for a specified map service in a web map.''' itemString = webmap_get_data_or_info( webmapId , portalUrl , token , '/data' ) for layer in itemString['operationalLayers']: try: url = layer['url'] logging.info(f"Searching item ---- {url}") except Exception as e: logging.error(e) return True dns = str(url).split('/') if dns[2].lower() == old_dns.lower(): dns[2] = new_dns.lower() logging.info('/'.join(dns)) layer['url'] = '/'.join(dns) item_info = webmap_get_data_or_info( webmapId , portalUrl , token , "" ) logging.info(itemString) logging.info('Updating: ' + item_info['title']) update_webmap_with_folder( webmapId , portalUrl , token , itemString , item_info['owner'] , item_info['ownerFolder'] ) def write_data(content): # filter out esri_ accounts # filter out false positive matches for web apps data_to_write = [json.loads(json.dumps(item)) for item in content if item['owner'][:5] != 'esri_' or item['type'] != 'Web Mapping Application'] with open(f'{get_script_dir()}//content.txt', 'w') as content_file: json.dump(data_to_write , content_file , indent=2) def read_data(): # Reads item data and returns a list of item id's with open(f'{get_script_dir()}//content.txt', 'r') as content_file: data = json.load(content_file) item_id = [] for record in data: if record is None: continue item_id.append(record['id']) return item_id def setup_log(folder, level, filemode): logging.basicConfig( level=level , filename=f"{folder}//log.txt" , filemode=filemode ) if os.path.isdir(folder) else os.mkdir(folder) def get_script_dir(): script_path = os.path.realpath(__file__) working_dir = script_path.split('\\')[0:-1] return '\\'.join(working_dir) if __name__ == '__main__': setup_log( f'{get_script_dir()}\\log' , logging.DEBUG , 'w' ) portal_url = 'https://gisportal.gauteng.gov.za/portal' old_dns = 'gisportal.gauteng.gov.za' new_dns = 'gisportal.gauteng.gov.za' username = 'hlindemann' password = 'Br@aks1809' referer = 'https://gisportal.gauteng.gov.za/portal' # Get a token for the source Portal for ArcGIS. token = get_token( portal_url , username , password , referer ) # Get a list of the content matching the query. write_data( search_portal( portal_url=portal_url , query='type:"Web Map"' , token=token ) ) input('Review content.txt before you continue') for id in read_data(): update_webmap_service( id , old_dns , new_dns , token , portal_url )
