Transect lines, parallel lines, offset lines
2007
01-16-2019 11:13 PM
DanPatterson_Retired
2 0 2,007
Lines
Different incarnations and names
Pretty easy to form the origin-destination pairs.
Start at a point.
Throw in horizontal and/or vertical offsets.
A dash of an azimuth/bearing.
A tad of NumPy
A bit of Arcpy and....
A good way to spend some time, so you write it down because you will forget and reinvent it later.
Almost forgot...
There is always one student that thinks outside the box.
Hmmmm could be a bonus here... I wonder if any of mine can replicate the compass with 10 degree increments?
In the attached code, I made these changes
    rads = np.deg2rad(bearing)
    dx = np.sin(rads) * dist
    dy = np.cos(rads) * dist
    n = len(bearing)
    N = [N, n][n>1]  # either the number of lines or bearings‍‍‍‍‍‍‍‍‍‍‍‍
And used this
b = np.arange(0, 361, 22.5)
a, data =transect_lines(N=1, orig=[some x, some y],
                        dist=100, x_offset=0, y_offset=0,
                        bearing=b, as_ndarray=True)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
You can't have it both ways in a manner of speaking.  By limiting N to number of bearings, you use numpy to generate the desired angles,.  There is no x or y offset since the origin is now fixed.
How to use the attached...
""---- use these as your inputs, with edits of course
# ---- make the x, y coordinate table
SR = 2951  # a projected coordinate system preferably
a, data =transect_lines(N=10, orig=[299000, 5000000], dist=100,
                        x_offset=10, y_offset=0, bearing=-10, as_ndarray=True)
p0 = r"C:\Your_path\Your.gdb\a_tbl"
arcpy.da.NumPyArrayToTable(a, p0)
# ---- now for the lines
p1 = r"C:\Your_path\Your.gdb\some_lines"
arcpy.XYToLine_management(p0, p1,
                          'X_from', 'Y_from',
                          'X_to', 'Y_to',
                          spatial_reference=SR)
PS
The python/numpy part is quite speedy, using variants of
%timeit transect_lines(N=10, orig=[0,0], dist=1, x_offset=0, y_offset=0, bearing=0, as_ndarray=True)
That is microseconds for the speed geeks.  I couldn't see a use case to test for larger arrays.
N    Time
    10     36.0 µs ± 309 ns per loop (mean ± std. dev. of 7 runs, 10000 loops each)
    50     39.3 µs ± 3.4 µs per loop (mean ± std. dev. of 7 runs, 10000 loops each)
  100     42.9 µs ± 6.57 µs per loop (mean ± std. dev. of 7 runs, 10000 loops each)
  500     46.5 µs ± 502 ns per loop (mean ± std. dev. of 7 runs, 10000 loops each)
1000     54.9 µs ± 1.39 µs per loop (mean ± std. dev. of 7 runs, 10000 loops each)
I didn't bother to test the featureclass creation since I have no control over that.
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
