Making text fields in Pro or any many other tabular formats requires that you specify the field width to accommodate the larges width. If you specify a size too small, data gets truncated, if it gets accepted at all.
For example, lets make a small data set which we might want to add to a table.
vals = 'abcdefgh' # -- an iterable to extract the values from
# -- generate the values
fld = [vals[i - 1] * i for i in range(1, len(vals) + 1)]
fld
['a', 'bb', 'ccc', 'dddd', 'eeeee', 'ffffff', 'ggggggg', 'hhhhhhhh']Now we cleverly create an array specifying a "field width"... I will use an array dtype in the following example.
z0 = np.array(fld, dtype='U3')
z0
array(['a', 'bb', 'ccc', 'ddd', 'eee', 'fff', 'ggg', 'hhh'], dtype='<U3')
# --- notice that the array isn't correct !!!!!
# --- there is truncation of the input values to a length of 3 (unicode text)Now add a field in a table in Pro and mis-specify the field width and see if the following holds the same as in the NumPy example (it does btw).
Soooo, what did NumPy do? They implemented https://numpy.org/neps/nep-0055-string_dtype.html
Here is how it works.
z0 = np.array(fld, dtype='U3') # -- again with the input data
z0
z1 = np.array(fld, dtype=StringDType()) # -- notice that unicode and size not specified
z1
array(['a', 'bb', 'ccc', 'dddd', 'eeeee', 'ffffff', 'ggggggg', 'hhhhhhhh'], dtype=StringDType())
# -- data size retained!!!This is one of the small obstacles that the arcpy people will have to deal with should they continue to move forward with supporting NumPy > 2.0.
A few of the affected...
ExtendTable—ArcGIS Pro | Documentation
FeatureClassToNumPyArray—ArcGIS Pro | Documentation
