Spyder 4 ... the python IDE for science
8770
6
12-12-2019 05:00 AM
DanPatterson_Retired
5 6 8,770
Spyder
Details as I go.  Everything is there to assist you from initial project thought to final application.
Right now... just the pics and a few tips.
An attachment of the first image, as well, if you want to explore in more detail.
Version
Spyder 4's current version and changelog can be tracked at...
Spyder changelog on GitHub
Theme choices
There are a variety of ways to layout and style the IDE.  A full dark theme is shown to the right .
Or you can split the themes and have different ones for  the editor and console.  The image below shows a lighter theme for the Variable explorer and the file explorer.
Separate (floating) or in-pane graphics available using direct access to Matplotlib.
Preference options
Graphics options
There is a new Plots window, or you can set your graphics to automatic to get a separate matplotlib graph window.  From there you can interactively alter the graphic to suit your needs.
You will also note, that svg inline graphics are supported.  I wrote a function to display numpy arrays representing geometry objects to get a quick preview without the need to create a featureclass.
File/project and script navigation
Help documentation and presentation
Help is everywhere.
The example to the right shows what a function docstring looks link in the console and in the help tab.
You can choose between coding styles within the preferences.
The numpydoc style used by packages like scipy, matplotlib, pandas to name a few, is shown below for comparison.
Editing tips
I hate scrolling, so when you get an error, click on the line number.  If it is in an imported script, you can even click on the script name to go there.
The object explorer can be used to retrieve information for objects.  This is useful for documentation purposes.
Finding stuff
When your package gets large and you are trying to locate something... Find is your friend.
A quick click and you are there to make edits, copy or just read.
Kite can be installed as well
Kite - AI Autocomplete and Docs for Python
6 Comments
DavidHoffer
New Explorer
Looks great - thanks for posting, Dan.
I am curious, however, what steps a user must perform to get Spyder 4 up and running? I had no trouble using the ArcGIS package manager to install Spyder and get it running, but it won't let me upgrade beyond Spyder 3.3.6.
I assume that there must be some package dependencies that won't allow me to upgrade to Spyder 4, and I am not familiar enough with conda to go in and mess around with dependency over-rides. So, any chance you could provide a quick update on how to upgrade to Spyder 4 and any issues that might arise within the Python env? Thanks!
conda update spyder --no-pin
DavidHoffer
New Explorer
Guaranteed safe? No impacts to be concerned about?
If things go bad.... just roll back to the revision number you want (don't use the [ ] though, just to be clear).
Worse comes to worse... just reinstall Pro from the *.msi file you should have downloaded.
conda list --revisions conda install --revision [revision number]
DavidHoffer
New Explorer
Sound plenty safe - many thanks for the info, Dan.
by Anonymous User
Not applicable
Thank you Dan! This is definitely the best way to do it.
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
