Point Tools for Pro
4186
05-14-2020 07:18 PM
DanPatterson
MVP Esteemed Contributor
5 5 4,186
Reincarnation as myself since being "retired" from my organization.  Published earlier, but with updates.
Download the zip.  Unzip into a folder.  Load the toolbox.
Alter
  • Options to move/translate/shift points to a new location using delta X and Y values
  • Rotate points as a whole about their centroid.
  • Sort points by coordinate options
  • Radial sort (aka, angle about the point centroid)
Analysis
  • Closest/near analysis
    • between layers
    • within layers
    • with a table
  • Concave and convex hulls. Yes, available without an Advanced license
  • Spanning tree.... connect points by polylines, representing the shortest path to connect them all.  Everyone loves a tree
  • Standard Distance, similar to standard deviational ellipse, except for the circle
  • Triangulation tools.  Voronoi, Delaunay space delineation.  No 3D analyst?  No problem, you can do it now.
Creation
  • Circle points.  Because you can.
  • Mesh points.  Nothing like points in a rectilinear pattern
  • Spaced Points.  Got to keep your distance?  Space points so that no point is closer than a certain value.
5 Comments
About the Author
Retired Geomatics Instructor (also DanPatterson_Retired). Currently working on geometry projects (various) as they relate to GIS and spatial analysis. I use NumPy, python and kin and interface with ArcGIS Pro.
Labels
