Math and Stats with NumPy... Normalize data
4134
03-18-2019 01:02 AM
DanPatterson_Retired
2 3 4,134
Short one
Came up in a question.  I sadly suggested a spreadsheet.  To correct this, here is the numpy solution.
Normalizing data...
Here is the input and output tables
names = ['a', 'b', 'c', 'd']
a = arcpy.da.TableToNumPyArray(out_tbl, names)
a0 = a.view('f8').reshape(a.shape[0], len(names))
dt = [('a1', 'f8'), ('b1', 'f8'), ('c1', 'f8'), ('d1', 'f8')]
n = normalize(a0)
new_names = ['a1', 'b1', 'c1', 'd1']
out = np.zeros((n.shape[0],), dtype=dt)
for i, name in enumerate(new_names):
    out[name] = n[:, i]
arcpy.da.NumPyArrayToTable(out, out_tbl+"norm")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
def normalize(a):
    # a is a (n x dimension) np.array
    tmp = a - np.min(a, axis=0)
    out = tmp / np.ptp(tmp, axis=0)
    return out‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Line 1 and 2, read the table from ArcGIS Pro
Line 3, 'view' the array as a floating point numbers.
Line 4, create an output data type for sending it back
Line 5, normalize the data
Lines 6 to 10, bumpfh to send it back to Pro as a table
Normalize... hope I got it right... take the array, subtract the min then divide by the range.  np.ptp is the 'point-to-point' function which is the range
Normalize by row, column or overall
Now, lets assume that an input dataset could be data arranged by row, column or as a raster...  We need to change of normalize equation just a bit to see the results.
Header 1
# ---- Adding an axis parameter ----
def normalize(a, axis=None):
    tmp = a - np.min(a, axis=axis)
    out = tmp / np.ptp(tmp, axis=axis)
    return out
a = np.arange(25).reshape(5,5)   # ---- some data
array([[ 0,  1,  2,  3,  4],
       [ 5,  6,  7,  8,  9],
       [10, 11, 12, 13, 14],
       [15, 16, 17, 18, 19],
       [20, 21, 22, 23, 24]])
normalize(a, axis=0)     # ---- normalize by column
array([[0.  , 0.  , 0.  , 0.  , 0.  ],
       [0.25, 0.25, 0.25, 0.25, 0.25],
       [0.5 , 0.5 , 0.5 , 0.5 , 0.5 ],
       [0.75, 0.75, 0.75, 0.75, 0.75],
       [1.  , 1.  , 1.  , 1.  , 1.  ]])
normalize(a, axis=1)     # ---- normalize by row
array([[ 0.  , -0.25, -0.5 , -0.75, -1.  ],
       [ 0.31,  0.06, -0.19, -0.44, -0.69],
       [ 0.62,  0.38,  0.12, -0.12, -0.38],
       [ 0.94,  0.69,  0.44,  0.19, -0.06],
       [ 1.25,  1.  ,  0.75,  0.5 ,  0.25]])
normalize(a, axis=None)  # ---- normalize overall
array([[0.  , 0.04, 0.08, 0.12, 0.17],
       [0.21, 0.25, 0.29, 0.33, 0.38],
       [0.42, 0.46, 0.5 , 0.54, 0.58],
       [0.62, 0.67, 0.71, 0.75, 0.79],
       [0.83, 0.88, 0.92, 0.96, 1.  ]])
Lots of stuff you can do
3 Comments
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
