Handy functions to save and restore the arcpy environment
988
05-05-2015 04:45 PM
curtvprice
0 0 988
I have run across the need to save and restore the arcpy environment. For example, a function (or a tool packaged in a function) may alter the environment and it would be nice to have an easy way to set it back at the end.
Arcpy provides the functions SaveSettings and LoadSettings, but they require that an XML file be created. I was having problems with these functions and had a epiphany that this could be more easily done by combining the ListEnvironments function and a Python dictionary.
Enjoy!
def SaveEnv():
    """Save selected arcpy environments as dict"""
    env_dict = {}
    for e in arcpy.ListEnvironments():
        if e not in ["scratchGDB", "scratchFolder", "packageWorkspace"]:
            env_dict = arcpy.env
    return env_dict
def LoadEnv(env_dict, display=False):
    """Load selected arcpy environments from dict"""
    for e in env_dict.keys():
        arcpy.env = env_dict
        if display:
            arcpy.AddMessage("{0:<30}: {1}".format(e, env_dict))
            print("{0:<30}: {1}".format(e, env_dict))
Here's how I am using these functions to keep GISProc from messing up environment when called:
def GISProc(arg1, arg2):
    envs = SaveEnv()
    try:
        # Tool goes here ...
        arcpy.env.extent = ...
        arcpy.env.cellSize = ...
    except:
    finally:
        LoadEnv(envs)
About the Author
PhD candidate (Geology), South Dakota Mines; Hydrologist, U.S. Geological Survey.
Labels
